1989-2006 KDX E-start!
Has thanked: 309 times
Been thanked: 144 times
Re: 1989-2006 KDX E-start!
Wow... They build their own electronic power valve, electric start, counterbalanced big bore engine... :bravo: :twisted:
And using CR500-compatible base gasket as a blueprint, & I presume CR500 engine mounting architecture as well...
Quite impressive :busted:
Been thanked: 55 times
Yeah, that engine is sweet but did you look at the price of that engine? :shock:
Has thanked: 43 times
Been thanked: 110 times
The engine is priced about where I'd have guessed and it's on par with a Rotax 500cc engine. But, for this Old Guy, either engine price is the amount that I pay for a used car!
jakeslouw
Country: South Africa
Post by jakeslouw »
Would the KDX need the charging system? Surely the lighting coil would provide enough charging amps?
Been thanked: 19 times
jakeslouw wrote: 05:26 am Aug 17 2023 Would the KDX need the charging system? Surely the lighting coil would provide enough charging amps?
Not the stock coil, unless maybe you have an SR. By the time the AC power from the coil gets rectified into DC, there isn't much left to run a light much less charge a battery.
Concur with Slick Nick about output wimpiness. However, it's.possible to operate the starter with a total loss system (e.g., no on-board charging). Some of us have run total loss ignition systems (e.g., battery only, no on-board charging) in road racing. The KDX engines turnover easy and, this plus starter draw, will easily allow a long day's riding without charging.
jakeslouw
Post by jakeslouw »
Slick_Nick wrote: 10:02 am Aug 17 2023
Got you. Although the old halogen bulbs were 55W, so going LED there should be enough left.
jakeslouw wrote: 09:39 am Aug 21 2023
Stock KDX headlight bulbs were only rated 30 watts.
pumpguy
Been thanked: 2 times
Post by pumpguy »
SS109 wrote: 01:08 pm Aug 21 2023
I'M surprised Slick Nick didn't mention his thread here on this site about rewinding the stock lighting coil for greater output. Also Ricky Stator offers a higher output lighting coil for the H series KDX. These double the output to around 80 watts.
Now weather this is enough to keep an E start battery topped up, IDK. I suspect no. Hopefully there's a multi-coil stator suitable to charge an e start battery available that can fit the KDX.
pumpguy wrote: 06:38 pm Aug 21 2023 I'M surprised Slick Nick didn't mention his thread here on this site about rewinding the stock lighting coil for greater output. Also Ricky Stator offers a higher output lighting coil for the H series KDX. These double the output to around 80 watts.
He did. It's even stickied in the "BEST OF THE BEST MODS" thread pinned at the top of this subforum.
A rewound stator should have no issue keeping a small motorcycle battery topped off unless you are running a big baja light setup and a bunch of electronics. Most bike batteries only accept between .75 and 2 amp charge rates
jakeslouw
Post by jakeslouw »
bufftester wrote: 05:28 pm Aug 22 2023 Most bike batteries only accept between .75 and 2 amp charge rates
That's what I thought: if I'm not running a headlight, the standard stator should be able to handle that easily.
The stator surely pumps out more than that, considering it needs to handle a 30W front light and a 5W taillight?
35W @ 12vdc = 2,9A
jakeslouw wrote: 06:19 am Aug 28 2023
35W @ 12vdc = 2,9A
Sorry but that is not correct. The stock KDX is AC voltage. That needs to be rectified to be able to charge a 12vdc battery. When rectified it will put out about 15W so roughly 1.25 amps. Still enough for a battery but don't add on anything else!
SS109 wrote: 10:40 am Aug 28 2023
35W @ 12vdc = 2,9A
Very interesting to know. I had no idea that 35W AC being rectified to DC was not equivalent to 35W DC... I should have figured that though... Undoubtedly this changes my outlook and approach to DC LED lighting conversions for our bikes.
jakeslouw
Post by jakeslouw »
Had a quick look at Dr Google who claims 12% to 36% reduction. However, the main bulb is 12VDC @ 30W and the tail light is 12VDC @ 5W : that implies a load of AT LEAST 35W AFTER RECTIFICATION.
The stock rear bulb is actually 10 watts.
https://www.partzilla.com/catalog/kawas ... aillight-s
jakeslouw
Post by jakeslouw »
KDXGarage wrote: 09:54 am Aug 29 2023 The stock rear bulb is actually 10 watts.
Which just reinforces my calculation: that means a minimum of 40W post-rectification = 3.33A available for battery charging.
If you're going to go the route of running a battery you really need to float the stators ground and get a quality rectifier/regulator. Even then with the stock stator you're going to be hurting for available juice if you add any lights. A rewound stator will give you lots more room, and the rewind is not difficult. You lose around 25%-40% converting AC W to DC W depending on the components you use.
GOT WOODS?
Country: NH USA
Been thanked: 14 times
Post by GOT WOODS? »
WELL, THIS IS GREAT NEWS!!!! :grin: :grin:
Start at the bottom:
Hi Dennis,
We are beginning to ship those kits out this month so I would estimate that new orders will be fulfilled around end of January.
Let me know if you have any questions, thanks!
Antoine Landry
<info@pantheramotorsports.com>
Sent: Monday, December 11, 2023 11:57
To: Panthera Motorsports <info@pantheramotorsports.com>
Subject: New submission from Contact Us
New inquiry on pantheramotorsports.com
Hi!
What is the current estimate on when the Kawasaki KDX220 electric start kits will be ready to ship?
Thanks,
Dennis
2003 KDX200: Bone stock
2003 KDX 220:
Boyesen reeds
Gnarly Gold Series pipe
Turbine Core 2 silencer
Fat Bars
Super Sport IMS pegs
Cycra Probend hand guards
Tusk dualsport light kit
LED headlamp
Airbox snorkel removed
Wiesco piston and rings
Thanks for the update!
