H series Kdx 200/220 exhaust port/flange size
JZ05220r
Post by JZ05220r »
Does anyone know exactly what the exhaust port size is on a kdx 200/220. I believe it’s 36mm but not 100 percent sure. I need mine repaired. Thank you
Re: H series Kdx 200/220 exhaust port/flange size
I have a stock 220 H cylinder on the shelf. How should I measure it? I have calipers in millimeter.
JZ05220r
Post by JZ05220r »
Molly's 70 wrote: 02:06 pm Jul 29 2023 I have a stock 220 H cylinder on the shelf. How should I measure it? I have calipers in millimeter.
Oh cool. It’s just the ID of the exhaust port/outlet. I’m looking for the measurement in mm. Thank you
Just a quick measurement with dial caliper shows 36-37mm exhaust port & 41-42mm for the pipe area.
JZ05220r
Post by JZ05220r »
Molly's 70 wrote: 02:35 pm Jul 29 2023 Just a quick measurement with dial caliper shows 36-37mm exhaust port & 41-42mm for the pipe area.
Thank you! I meant the area where the exhaust gets pushed in on the cylinder btw. I can see my terminology was alittle off.
