Coolant hoses not pressurized. Just as squishy hot as cold. UPDATE: was as simple a new 1.8 bar radiator cap.
JZ05220r
Has thanked: 3 times
Post by JZ05220r »
I can remove the radiator cap with out any noise or spew whatsoever :?
Been thanked: 57 times
Re: Coolant hoses not pressurized. Just as squishy hot as cold.
Then you have a leak somewhere. Cap, hose connections, head gasket, something.
JZ05220r
Post by JZ05220r »
SS109 wrote: 10:35 pm Jul 19 2022 Then you have a leak somewhere. Cap, hose connections, head gasket, something.
The cap appears fine and I haven’t lost coolant in the radiator or the expansion tank. I’d think if it was the head gasket the cooling system would be pressurized.
pumpguy
Been thanked: 2 times
Post by pumpguy »
Is there a way you can determine the temperature? One of those IR guns might be useful here. I thought I saw radiator caps with built in thermometer.
Might not be hot enough to get up to pressure.
JZ05220r
Post by JZ05220r »
pumpguy wrote: 01:55 pm Jul 20 2022 Is there a way you can determine the temperature? One of those IR guns might be useful here. I thought I saw radiator caps with built in thermometer.
Good idea and the temps have been in the 80s and 90s and judging how how the engine is the coolant must be up to temp. Every water cooled small engine I have came across, the hoses were pressurized.
sounds like your water pump isn't
