Weird 1991 exhaust valve issue
wfoerk
Post by wfoerk »
Hi all, yeah, a strange issue with my 1991 kdx 200 exhaust valve. This is a bike that was a basket case I'm fixing up. I put the KIPS valves in the cylinder (fresh Powerseal job on cylinder, steel exhaust valves, new o-rings in KIPS parts), and they all work great until I put the cover on the front exhaust valve. When I tighten the front cover, the KIPS system binds to the point it won't move. I'm sort of lost here and any help would be appreciated.
Thanks in advance-
Been thanked: 2 times
Re: Weird 1991 exhaust valve issue
Are the bolts too long?
Has thanked: 71 times
Been thanked: 20 times
I'll guess you don't have the center valve lined up on the teeth correctly. It has been a long while since I did one, but getting it lined up was a bear for me.
hi-def
Country: New Zealand
Post by hi-def »
I followed the excellent instructions in the thread linked below for making sure the KIPS valves were installed and timed correctly
viewtopic.php?f=115&t=15320
jaunt
Post by jaunt »
wfoerk wrote: 04:36 pm Feb 13 2022 Hi all, yeah, a strange issue with my 1991 kdx 200 exhaust valve. This is a bike that was a basket case I'm fixing up. I put the KIPS valves in the cylinder (fresh Powerseal job on cylinder, steel exhaust valves, new o-rings in KIPS parts), and they all work great until I put the cover on the front exhaust valve. When I tighten the front cover, the KIPS system binds to the point it won't move. I'm sort of lost here and any help would be appreciated.
Thanks in advance-
I have the same issue, did you figure it out?
