Petcock Pipe Came Off Inside Tank
stnd
Post by stnd »
Hi,
On a recent ride my carb started pissing out fuel. I opened up the carb to inspect the float needle/seat and discovered a bunch of dirt and grime on the bottom of the float bowl. Cleaned it up but it did not solve my problem. Today I drained and removed the fuel tank and heard something moving around inside. Turns out one of the petcock straws/pipes fell off.
My question is can i just push it back in and keep on keeping on, or do I need a new petcock?
TwistedRoot
Re: Petcock Pipe Came Off Inside Tank
Post by TwistedRoot »
I had the same issue after buying my bike. I took it apart and used a VERY small amount of JB Marine weld. Its been holding up great for the last 2 years.
2002 KDX 200
2003 KDX 220
stnd
Post by stnd »
Thanks, I cleaned it up and just pushed it back in. Took quite a bit of force to get it to seat all the way so I figure it may be a while until it comes out again. Let's see how long it lasts. If I feel like taking it out again I'll use a bit of loctite.
I haven't gotten into my tank/petcock yet. Thinking when I do I'll replace it with a shorter one that doesn't hang down so far, the longer design just seems susceptible to getting smacked while riding in the woods or dropping in rough ground.
QUESTION: is that a screen on the two intakes? Is that something you guys clean on a regular basis?. Seems like it act like a fuel filter if that's what it is.
Yes, it’s a screen. Frankly I don’t clean mine unless I notice a problem with fuel flow.
+1 with Doakley, if you are using clean fuel cans and pumps you shouldn't see much crud on those screens.
