Kdx200 bogging until stall on top gear
Apk_kdx
My 1987 KDX200 was running and I took her on a couple rides and noticed randomly in 6th gear the bike will bog out and stall. I’ve heard it’s called a lean bog but I don’t fully know
- Been thanked: 10 times
Re: Kdx200 bogging until stall on top gear
Make sure your fuel flow is adequate and there are no blockages anywhere.
- Has thanked: 191 times
Have you done a full throttle plug chop to check for a proper main jet size?
Apk_kdx
I’ve cleaned out the carb and I had to replace the throttle cable. It’s a mikuni carb and it doesn’t have a part number
Jets should have a number on it. If it does not, then buy one that does. Buy a genuine Mikuni jet.
