Rocker Arm Bolt AAARRRGGGH!!!
GOT WOODS?
Country: NH USA
Been thanked: 12 times
Post by GOT WOODS? »
So I'm trying to service my rocker arm bearings and am finding it impossible to get the rocker-arm-to-frame bolt out. The way that it is sitting in the frame makes it impossible to get a direct hit on the bolt to drive it out. Anybody have this issue and found a good way to get this out? I'm thinking of heating both ends of the bolt up to get them to expand enough to maybe stretch the bolt hole in the bearing spacer and break the rust that is presumably holding the bolt in, then let it cool down and beat on it as well as I can. Anyone ever try this? Anything to watch out for? Thanks!
2003 KDX200: Bone stock
2003 KDX 220:
Boyesen reeds
Gnarly Gold Series pipe
Turbine Core 2 silencer
Fat Bars
Super Sport IMS pegs
Cycra Probend hand guards
Tusk dualsport light kit
LED headlamp
Airbox snorkel removed
Wiesco piston and rings
kdxdazz
Country: thailand
Been thanked: 41 times
Re: Rocker Arm Bolt AAARRRGGGH!!!
Post by kdxdazz »
Do you mean swingarm bolt? What is the rocker arm bolt
kdxdazz
Country: thailand
Post by kdxdazz »
If you are meaning swingarm bolt, lay the bike on its side and spray the bolt with penetrating oil. Let it sit overnight then hit with a brass punch and hammer, if you get some movement lay the bike on its other side, and repeat the process, keeping doing this until you work it free. Heating the bolt will do nothing as the rust is at the swingarm sleeve, bearing, and swingarm bolt, the heat won't penetrating that far
pumpguy
Been thanked: 2 times
Post by pumpguy »
I think he's meaning one of the bolts that go through the 39007 UNI TRAK suspension arm. It's been awhile since I did mine, but don't recall having any problems.
Penetrating oil and patience usually works
Has thanked: 159 times
Been thanked: 39 times
yep, what doakley said
I cut one out before. Totally not fun.
Oil and heat.
tucker
Country: New Zealand
Post by tucker »
use heat if you can, or get an open end wrench on it and hit it with a rubber mallet after applying some penetrating lube.
Has thanked: 5 times
I just dealt with this yesterday. Mine was really seized (not my fault I swear - I just bought it!). After removing the lower chain roller guide, I put a shallow impact socket on a 25" Harbor Freight breaker bar on the left (bolt head) side, and a box wrench on the right (nut) side. Came right off.
