Crank compatibility HELP
KDXhIllBillY
- Country: America
Hey fellas.... well I’m still building the 2003 KDX 220. I have everything I need to do a complete rebuild. HOWEVER I now need a whole new crank and I need to know what years of the 200 and 220 Cranks that will work for my 2003 220. If anyone has one for sale please let me know. I’m dying to get this thing done so I really appreciate any help.
- G22inSC
Re: Crank compatibility HELP
Any "H" model (1995-2006) should fit. I'm not aware of any differences within these years. If you want to verify, check one of the online parts sources and verify the OEM part numbers.
'10 Honda Recon (wife's)
'08 Kaw KX65 (Sold)
'07 KTM 50SX Sr. (Sold)
'09 Yam PW50 (retired)
'97 Kaw KX250 (Sold)
Gallery
2005 KDX200 Bike Profile
'08 Kaw KX65 (Sold)
Gallery
KDXhIllBillY
- Country: America
Cranks are the same far as 220s and 200s right...
Only difference I’ve heard is piston and carbs.
I need all options bc apparently it’s not easy finding one.
- G22inSC
there are a few differences such as piston, carb, chain, etc. but I don't think there are any differences with the cranks
'08 Kaw KX65 (Sold)
Gallery
'08 Kaw KX65 (Sold)
Gallery
- ss109
- Has thanked: 30 times
- Been thanked: 45 times
Cranks are 100% interchangeable between 1995 and 2006 200 and 220cc bikes.
KDXhIllBillY
- Country: America
So I’m looking for 220 or 200 1995 to 2006
Thanks fellas. Hopefully one will pop up here or Ebay soon!
pumpguy
- Been thanked: 2 times
What's the problem thats causing you to look for a whole new crank?
If it's a bad lower end bearing, I would be looking for a replacement crank pin and rod assembly. Hot Rods? Wiseco? IDK. Then get, or find someone with a 20T press. It doesn't take much to rig up a pair of centers, or use V blocks to check the alignment. Dial indicators are really cheap these days, and the alignment procedure is written up in the service manual and other places too. I've done this several times.
- Has thanked: 159 times
- Been thanked: 39 times
What happened to the old one that it has to be replaced?
This Kawasaki 13031-1382 CRANKSHAFT-COMP fits the following models and components:
Kawasaki Motorcycle 1996 KDX200 - KDX200-H2 Crankshaft/Piston(s)
Kawasaki Motorcycle 2005 KDX220R - KDX220-A12 Crankshaft/Piston(s)
Kawasaki Motorcycle 2001 KDX220R - KDX220-A8 Crankshaft/Piston(s)
Kawasaki Motorcycle 2000 KDX200 - KDX200-H6 Crankshaft/Piston(s)
Kawasaki Motorcycle 2004 KDX220R - KDX220-A11 Crankshaft/Piston(s)
Kawasaki Motorcycle 2003 KDX220R - KDX220-A10 Crankshaft/Piston(s)
Kawasaki Motorcycle 2001 KDX200 - KDX200-H7 Crankshaft/Piston(s)
Kawasaki Motorcycle 1999 KDX220R - KDX220-A6 Crankshaft/Piston(s)
Kawasaki Motorcycle 2004 KDX200 - KDX200-H10 Crankshaft/Piston(s)
Kawasaki Motorcycle 2005 KDX200 - KDX200-H11 Crankshaft/Piston(s)
Kawasaki Motorcycle 2000 KDX220R - KDX220-A7 Crankshaft/Piston(s)
Kawasaki Motorcycle 2002 KDX220R - KDX220-A9 Crankshaft/Piston(s)
Kawasaki Motorcycle 1998 KDX200 - KDX200-H4 Crankshaft/Piston(s)
Kawasaki Motorcycle 1995 KDX200 - KDX200-H1 Crankshaft/Piston(s)
Kawasaki Motorcycle 2006 KDX200 - KDX200H6F Crankshaft/Piston(s)
Kawasaki Motorcycle 1999 KDX200 - KDX200-H5 Crankshaft/Piston(s)
Kawasaki Motorcycle 2003 KDX200 - KDX200-H9 Crankshaft/Piston(s)
Kawasaki Motorcycle 1997 KDX200 - KDX200-H3 Crankshaft/Piston(s)
Kawasaki Motorcycle 1997 KDX220R - KDX220-A4 Crankshaft/Piston(s)
Kawasaki Motorcycle 1998 KDX220R - KDX220-A5 Crankshaft/Piston(s)
Kawasaki Motorcycle 2002 KDX200 - KDX200-H8 Crankshaft/Piston(s)
