cyclinder compression testing
Merchman
- rungrandpa
- Country: U.S.A.
- Has thanked: 1 time
Re: cyclinder compression testing
For compression testing I bought a $30.00 unit from O'Reilly auto parts.
https://www.oreillyauto.com/detail/b/mi ... orer?pos=1
BTW, I was taught the secret to using a compression test is to use the same gauge in exactly the same manner EVERY time and keep a record of trends more so than actual numbers. In my case I always test stone cold, throttle wide open, kick 8-10 times rapidly until the gauge stops rising. 160 on my gauge might be 150 or 170 on yours, especially if you test differently. Just my $.02.
- Has thanked: 24 times
- Been thanked: 28 times
Well said!doakley wrote: 02:18 pm Jun 17 2020 BTW, I was taught the secret to using a compression test is to use the same gauge in exactly the same manner EVERY time and keep a record of trends more so than actual numbers. In my case I always test stone cold, throttle wide open, kick 8-10 times rapidly until the gauge stops rising. 160 on my gauge might be 150 or 170 on yours, especially if you test differently. Just my $.02.
As an adder, compression checks are just one indicator, not the “be all end all”. We don’t talk about it much it seems in motorcycles but a bore scope to let you actually see what the cylinder looks like is a very informative tool.
I just stick my phones camera over the plug hole with the flash on. The future is great.
We use the phone a lot in construction. All you need is a slot big enough to slide half your phone in the hole and take pics with flash inside of walls or soffits. It works great but never thought to use it over the spark plug hole. The inspection camera “bore scope” I have doesn’t flex enough so I only get to see the top of the piston and not the walls.
- Two_stroke_brit
the cheap one i got of fleabay comes with aslip on 45 degree mirror ,ideal for just that.John_S wrote: 10:06 am Jun 20 2020 We use the phone a lot in construction. All you need is a slot big enough to slide half your phone in the hole and take pics with flash inside of walls or soffits. It works great but never thought to use it over the spark plug hole. The inspection camera “bore scope” I have doesn’t flex enough so I only get to see the top of the piston and not the walls.
she might be older but still a fun ride.
