Build your own KDX fork cartridge holder
dsedam
So, after a many a read on several sites and trying to track down a cartridge holder tool, I made one for under $12.
Here is what I used all from a local lowes:
1 - 1/2" x 30" iron pipe
https://lh4.googleusercontent.com/-vjBS ... 165903.jpg
1 - Lfa-668 brass garden hose adapter.
https://lh4.googleusercontent.com/-hstn ... 165844.jpg
The brass was used for a couple reasons -
1. It's soft and your reaching aluminum...
2. Easy to grind with a file for deburring...
Screw the adapter onto the pipe as tight as you can, you can even lock tight it on, I did not.
Using a grinder, cut off the excess threads, making flush the brass "nut" and iron pipe.
https://lh6.googleusercontent.com/-doXy ... 170008.jpg
https://lh5.googleusercontent.com/-aX9X ... 165820.jpg
Deburr the cut and the edges of the nut portion of the brass.
https://lh4.googleusercontent.com/-33jr ... 165827.jpg
Clean the internal span of the pipe, you never know what goodies are in there and it will keep you from potentially scratching your damper rod. Wrap the first 20" or so in electrical tape as it keeps it nice and soft for the metal components touching each other...
Finished product:
https://lh5.googleusercontent.com/-99Tq ... 165810.jpg
Insert the tool over the rod and down into the cartridge, lining it up and you should feel it lock in. Using a 14mm allen socket , found at auto zone in a 3 pack 12mm, 13, mm, 14mm for $12, unscrew your valve.
Dan
New to me 2004 KDX 200
Previously owned 1994 KDX 200
Finished product:
Dan
Dan
1994 KDX 200
1994 KDX 200
- Gotanubike
Great post, how did you figure a garden hose adapter fits the ARP 12 notched fitment on the damper rod? That adapter is imperial.
1990 KDX200
dsedam
Re: Build your own KDX fork cartridge holder
At my lowes the pipe and brass fittings are right across from each other. I knew I needed a soft metal and the brass fittings fit the bill. Bought the nearest size, a little grooming and voila...
Dan
1994 KDX 200
1994 KDX 200
sthutch
Dan,
I gotta say THANK YOU!!! I haven't ridden in a couple years due to loosing my hearing (and balance) in my right ear. Finally, I feel confident in my ability to ride so I pulled my KDX out of storage to get ready. When I put it away I knew I had a leaky fork seal, so that was the first thing on the agenda. A quick search here yielded the tool I needed, and how to make it. Since this was an older post, I did an online search at my local Lowes for the adapter to make sure they carried it. They didn't carry it, but Home Depot did! I went and picked up the parts, followed your steps and presto, had my tool. It worked perfectly!!!
Thanks for posting this!
Sthutch
Sthutch
Sthutch
1st Bike: '72 Arctic Cat Whisker (rode it to the wheels fell off)
2nd Bike: '76 KT250 Trials (gone, but not forgotten)
3rd Bike: '01 KDX200
4th Bike: '96 DS80 (okay, my 9yr old's and it's gone)
5th Bike: '04 RM65 (okay, he's now 10 and it's gone)
6th Bike: '08 KTM 105xc (okay, he's now 13)
7th Bike: '06 KTM 200xc-w (okay, he's now 16)
pumpguy
- Been thanked: 2 times
Would anyone be able to post pictures of parts used? At this late date those originally posted are no longer available.
JRod396
Pumpguy, what did you end up using or finding? The LFA-668 is no longer available
tystick82
I just made my cartridge holder the other day. Worked great with a little grooming. The brass part lfa-668 was available at my local Walmart. You could surely pick one up at a plumbing supply store as well. Hope this helps
russell3
I was also looking into how to make one of these and didn't really find a good video or pics of one. This is the best thread I've found on the subject, but as stated, the pics don't work in the links anymore. I decided to just built one and did a youtube video on how to do it. I used a piece of pipe and a drilled out bolt head(could have used a nut, but the store didn't have one at the time). I just welded them together. pretty simple. Might not be as nice as finding the threaded adapters spoken of here, but it's an option and it worked great for rebuilding my forks. Hope this helps someone out.
KingDaddyX
- Has thanked: 2 times
I used a ford explorer radiator intercooler fitting. I had this stuff laying around. It was hollow and had an o ring inside it that protects the damper rod very nicely. The cable protector was thin enough that it made a good liner because my pipe was a little rusty.
The square tube chucks up nicely in the vise, and I can stick a cheater bar over it too
- image.jpg (3.39 MiB) Viewed 286465 times
- image.jpg (2.83 MiB) Viewed 286465 times
- Has thanked: 159 times
- Been thanked: 39 times
pretty cool with the o-ring in it!
If anyone is not a home welder, the FRP tool (if he still makes and sells them) is great!
