Hi there,
I am in the process of replacing my basket & clutch plates on my 95 200. I was wondering if there is a post/video here that shows the step by step removal procedure? I have Cyclepedia, but it's seems a little robotic for my liking. Appreciate the feedback.
95 kdx 200 clutch basket/plates removal
95kdx
- ss109
- Has thanked: 33 times
- Been thanked: 57 times
Re: 95 kdx 200 clutch basket/plates removal
No video that I know of. It's pretty straightforward though. Just follow everything step by step. It's a good idea to use a flywheel holder on the ignition side or improvise a way to do it without damaging the clutch basket. Also, an impact wrench really helps.
- Been thanked: 10 times
Pretty much any 2T video on clutch replacement will give you the general idea, along with the specifics from Cyclepedia.
- Has thanked: 193 times
- Been thanked: 49 times
Welcome to kdxrider.
I made a clutch holding tool out of an old steel clutch plate and a piece of scrap steel, bolting then together with some nuts, using nuts in between to space it. Works good if you don’t need to do the job often.
