'86 - Down the Rabbit Hole
Clatter
Motor Together!
Post by Clatter »
Yesterday was a good day..
Started off with my oldest helping get a feebay exhaust pipe ready for paint.
It was either packed with shredded newspaper, or a mouse got in there or...?
Stuff kept coming and coming when we blew it out.
See also the pile of old nuts we put in there.
After shaking and shaking and shaking it around,
Piles of red flaky rust dust came out.
Pretty soon our friends came over and helped sand the old crusty paint off.
We also re-packed the muffler and gave it a polish, even
(it was so battered and scratched it didn't look like much).
I got on with putting a motor together.
Rather than blueprint the thing, check port alignment with the piston, deck height, etc.
I just stuck the sucker together.
It's really hard for me to install any gasket dry.
Was out of indian Head shellac, so I put some Aviation on the base gasket.
For the head gasket, I used aluminum paint;
This is an old-timer trick I just can't help doing on any semi-metallic head gasket.
I just had to..
Here's the parts for the reed valve area.
The manual doesn't show a gasket between the cage and the boot thingie,
So I put some aviation on where it woulda gone, unlike in the pic here.
Was going to put these Boysen reeds on, but they just seemed so different than the ones in place.
Took and flipped the ones on it over, but that made them worse, so put them back.
"I have some reed cages I'll sell ya".. :roll:
People are still happy to trade money for parts that don't work.
it's always about getting the money, right?
Since the bike always ran FINE with the reeds just like they were,
It went back together just like it was.
[Image
About the blue tape on the pictre above..
Apparently, the last guy who worked on this really didn't believe in washers.
Must have been against his religion or something.. :roll:
Certain washers, like under the throw-out pushrod, under the rotor bolt, those are specialized,
And obviously have to go in.
But here's an odd one;
Washers on each side of the plastic spacer inside the kicker return spring..
Manual shows them:
Partzilla shows them - 92022C-271:
Yet, ALL THREE of the motors i took apart had NO shims on either side of the plastic spacer.
Neither did two extra kicker assemblies i ended up with.. :?
Anybody know the truth on this one?
Here I'm all going fishing for some shims, and do the whole end-play/shim/check routine,
But maybe they were eliminated later on?
It obviously starts the bike without them,
But who wants a sloppy/slipping kicker that eats ratchet gears??
THIS is why you never rebuild a basket case.
ALWAYS start with the best example you possibly can!
WAY more fun to just go and shoot a potato gun!! :lol:
Re: '86 - Down the Rabbit Hole
Post by kdxsully »
I have an 84 motor AND an extra kicker assembly and neither has those washers either. Good to know I’m not alone.
I also don’t have reed stops, and I’ve worried that one might flex too much and break, but I’ve been fine so far.
What kind of rod did you end up going with??
Clatter
Post by Clatter »
That rod is from Hot Rods.
It was installed on a crank done up by Off-Road Innovation.
It didn't hit the head!! :-) :-) :-)
Good job on the continued work! I can't see "no washers" as being a good thing. On some Boyesen, they come with different reed stops and one does not use stock.
Clatter
Home Stretch!
Post by Clatter »
After sitting disgruntled over missing trivialities,
I finally realized that I have most everything here now.. :?
What was all of this stuff, again..?
One thing that was really giving me the hump was a pool of oil underneath each "rebuilt" fork leg..
Man, I hate re-work.
You would think a rebuild kit would include seals..
What you don't do correctly, you can do again!
Somehow, somewhere, someone has come up with a way to NOT make a mess doing this job..
Broke this doohickey trying to hold it during tightening;
Spare core motor saves the day!
Look who finally came home!
That led to digging out parts and cleaning/fitting/fettling..
Been wanting to install these little gems for a loonng time. :cool:
After almost ten hours, it actually starts to look like a KDX.. :grin:
Late at night,
Stuff just set in place for now,
And to figure out what's gone missing over the years..
The list isn't too bad,
So one or two more sessions should get us there..
Can't wait! :mrgreen:
LOOKING GOOD! Congratulation on getting back at it.
Pressingonward
Post by Pressingonward »
Great thread, thanks for documenting this considerable project! I have a 1988 that I'm trying to get fixed up and running. Paid $450 for it and felt kind of stupid once I started noticing all the broken parts that I should have seen before handing over my money. Broken right side engine case, missing spacer on front axle, tons of play in every rear suspension joint, etc. I have to say though, yours looks like it was an even worse starting point (although to be fair I've never heard mine run yet lol). Kudos for persevering!
Two tips for you based on what I've discovered so far working on mine:
  • 1. Those small bearings in the engine covers can be removed without a specialty puller or cutting them apart. It will destroy your paint though. Set the cover upside-down on a wood surface. Heat the outside of the bearing boss with a propane torch. You should hear the bearing fall onto the bench after 20 seconds or so. If not, give the bearing boss a couple smacks with a deadblow hammer and it should drop out. Probably not much help now, but might help someone in the future.
    2. My bike came with a JT sprocket on it. It had a ton of slop on the shaft and there was noticeable wear on the shaft splines. Per a recommendation on this forum, I ordered a JT sprocket for an 85(?) KX500 which has an extended flange to ride on the undamaged portion of the splines (requires that the spacer behind the sprocket get cut down to allow for the wider sprocket). I was quite surprised to find that the kx500 sprocket fit nearly as loosely on the undamaged spline area as my old one did. I returned it and bought an NOS Kawasaki KX500 sprocket, and it fit tight on both the undamaged and damaged areas of the splines. In other words, I would NEVER run a JT sprocket, their tolerances are very loose and will wear out your countershaft based on what I can see on my bike and threads I found online after noticing the slop. If your splines are OK still I probably wouldn't bother with the KX500 sprocket, but I would highly recommend running a stock Kawasaki sprocket
Let me know if you get stuck on any small detail questions and I can look at my bike for reference to hopefully help you out.
I have never heard that on a sprocket. Thanks for the heads up.
Post by kdxsully »
Great, now I gotta check my splines and sprocket. Thanks for the heads up
Clatter
Almost There...
Post by Clatter »
Spent a couple of days after work..
Put some stickers on;
Couldn't for the life of me get that big plate to lay down without wrinkles!! :evil:
We'll just have to put some numbers on to cover them up.
How old was Jason, again?? :lol:
Could NOT for the life of me, find this bolt anywhere..
This goes thru the lower shock mount eye and the two plates that attach to the frame.
Kawasaki Part# 130P1260 It's not here anywhere,
or anywhere on the Internet or anywhere else...
I found an 8.8 bolt/nut (similar to SAE grade 5 :roll: ) Non-flanged, with coarser threads, at my local Ace Hardware.
Maybe one of you guys out there has a dead bike I can steal a bolt/nut off of? :please:
I don't really want to run it, but also don't really have a choice.
Because it's not subject to shock loading,
it might just be OK?
(Pa-Dum-*tish*) :mrgreen:
Thanks folks, I'll be here all week.. Don't forget to tip your waitress...
There were little cracks all over the intake boot if you bent it over.
The rednecks had smeared some roof mastic, or that A/C duct sealer, on to help..
Because it was the wrong color, and needed more, this redneck added some vinyl coating
(Always do your hack work in the correct color).
The list of little things to:
Scrape off,
Clean in gas with a toothbrush,
Wire-wheel,
Glass-bead,
Cad-plate,
And install,
Has gotten pretty small..
looks about the same to me
https://cdn11.bigcommerce.com/s-xzmeigl ... mbypass=on
Be sure to tighten it to the proper torque. The shock will come loose, then you will jump a small double jump and bend the shock rod. Or at least I did many years ago. :oops: :oops: :oops:
Pressingonward
I don't have a spare of that particular bolt, but I can check the one on my bike to see what grade it is. I might even have a bolt of the same size in my stash, I can check.
Nice job on the air boot reseal, I need to do the same thing to mine.
Post by kdxsully »
My lower shock mount was held in with a smaller bolt, but and washer when I got it. :mad:
I had picked up an M12 bolt with the correct pitch at Lowe’s before I found an OEM on eBay
pkenney
Been thanked: 2 times
Post by pkenney »
Hey Clatter,
I sent a reply to your PM but it is stuck in my outbox...tried again and same thing.
Either I don't know how to send a PM or you can't receive them?
I still have a spare lighting coil.
I dug it out of the crate and its not in as good shape as i remember it though.
Not really looking to get anything for it so I can ship it to you, let me know your address.
Its a lot of work documenting a rebuild and I've enjoyed seeing your progress and updates.
Are you still interested in a slotted baseplate too?
Pressingonward
I took a look at the lower shock mounting bolt. It has a weird "q" symbol on it that is probably a manufacturer's mark. No hardness rating unfortunately. It measures 56mm long. I didn't pull it out to measure the diameter, but assuming it is a fine thread M12 like kdxsully said, I think you need a JIS flange head M12x1.25x55 grade 10.9, like this one I found with a quick google search:
https://www.boltsandnuts.com/shop/m12-1 ... lear-57273
Pressingonward
Actually, let me doublecheck the length on that, I may have written it down wrong
130P1260 means 12 x 60
Clatter
Post by Clatter »
A few more little things to post up..
Thanks for the help with the bolts, guys,
Very much appreciated.
Turns out Wal-Mart had my 10.9 bolt and nut.
See also something Wiseco was cool enough to just send me.
Not that I want to,
but,
I put a circlip in -just- a bit wrong.
Couldn't sleep with that, having a new cylinder and all.
So,
Yes,
The top end will have to come back apart. :roll:
No big deal at this stage I guess..
Got the tires/tubes/strips and a check of my lace/true job at a local shop.
Decided to go with the dual-sport tires since we're going to at least try for a plate somehow one day.
Even if they do look kind of sissy.. :mrgreen:
Had to just mock everything up, and stare at it, even though there's still PLENTY to do..
Looking good!
Also, good job on having enough light to see. Good lighting helps so much!
Post by kdxsully »
Wow! By the time I would be done with this I’d think twice about even riding it.
