How can you see the color? My sight glass is so worn that my oil could be glowing and I wouldn't be able to see it!KDXGarage wrote: 03:36 pm Aug 06 2019 Around there, usually go by color change. One time, I looked up all the parts prices. It scared me!
Clutch slip!
- ss109
- Has thanked: 33 times
- Been thanked: 57 times
Re: Clutch slip!
Re: Clutch slip!
Same. I tried to thoroughly clean mine to no avail. I'll wait to spend 15 bucks on something that I'll probably break when trying to install.
- Has thanked: 193 times
Re: Clutch slip!
I don't ride in sand all the time. :-)
Strictly Kdx
Re: Clutch slip!
Yeah I haven’t been on the bike that much because of it trying to get a basket is a little pricey, any aftermarket baskets you suggest?kdxsully wrote: 07:46 pm Aug 05 2019Was it just that basket or is the boss notched too? Also, check to see if the gap between your friction plate fingers and the basket is still in spec. I think you can cause some damage over time if it’s out of spec. I’d be on the lookout for a basket.Strictly Kdx wrote: 10:47 pm Aug 04 2019Yeah the notches were the real problem, they were horrible. Now as far as oil goes I went back to normal stuff I used but I never found an oil that would last for more than 2 or 3 rides is that all there is to it or is there something that actually last a little whileKDXGarage wrote: 01:56 am Aug 03 2019 Just for fun, do only one change, the oil. See how the different oil affects it, then go for the basket filing.
Wiseco used to make baskets. ProX used to also.
Re: Clutch slip!
Wiseco
Pro-X
Pro-X
Re: Clutch slip!
I know pro-x is made in Japan. Does wiseco make anything well besides pistons?
- ss109
Re: Clutch slip!
Wiseco and ProX are owned by the same company, Race Winning Brands (http://www.racewinningbrands.eu/). They also own Rekluse.
That said, I know Wiseco baskets to be very nice.
Re: Clutch slip!
I would not buy a Wiseco crankshaft. I would gladly buy a basket or piston.
- ss109
Re: Clutch slip!
Yup. Their cranks tend to be hit or miss with the trend more to the miss side.KDXGarage wrote: 05:40 pm Aug 25 2019I would not buy a Wiseco crankshaft. I would gladly buy a basket or piston.
Re: Clutch slip!
You get what you pay for??
I would much rather rebuild an OEM than use a new Wiseco, way too many horror stories.
- ss109
Re: Clutch slip!
Exactly! I know a factory crank is good whereas the Wiseco you're rolling the dice.KDXGarage wrote: 08:40 pm Aug 26 2019 You get what you pay for??![]()
