Gear drum
- Molly's 70
- Has thanked: 6 times
- Been thanked: 3 times
Re: Gear drum
It only goes together one way.
Parney
- Country: England
Re: Gear drum
Many thanks all that side done if that’s the case fighting with needle roller at minute tried heat tried bearing puller thing will not move soaking it in penetrating oil for 24 hours
- Molly's 70
Re: Gear drum
1 or 2 days of a good penetrating oil can make a big difference. Which needle bearing are you trying to pull out?
Re: Gear drum
A lot of people say to just put the case in the oven.Parney wrote: 03:18 pm Jul 25 2019 Many thanks all that side done if that’s the case fighting with needle roller at minute tried heat tried bearing puller thing will not move soaking it in penetrating oil for 24 hours
- Molly's 70
Re: Gear drum
Agreed. 275 - 300 degrees F. Use gloves & turn the case over on a piece of wood, smack it down to help. Inside bearings may still need the "slide hammer/puller tool" as I call it.kdxsully wrote: 07:23 pm Jul 25 2019A lot of people say to just put the case in the oven.Parney wrote: 03:18 pm Jul 25 2019 Many thanks all that side done if that’s the case fighting with needle roller at minute tried heat tried bearing puller thing will not move soaking it in penetrating oil for 24 hours
