'89 KDX 200 Plastics
92driver
Country: Australia
Post by 92driver »
Hi, Just wondering if later model plastics will fit on an '89 KDX 200? In particular I am after a rear fender, do the UFO fenders fit? Do late model tank/plastics fit?
Thanks in advance.
Has thanked: 27 times
Been thanked: 31 times
Re: '89 KDX 200 Plastics
None of the later KDX plastics fit other than the front fender. The only interchange is the side number panels are the same as the KX500.
92driver
Country: Australia
Post by 92driver »
Thank you, much appreciated. Anyone know of a good source for a rear fender and headlight surround? Thanks.
Has thanked: 110 times
UFO might still make a rear fender. Look on Dennis Kirk.
As far as the "just" the headlight shell, OEM or just buy a whole new headlight.
There are a few to choose from, just be sure to check wattage.
Welcome to the forums!
92driver
Country: Australia
Post by 92driver »
Thanks. The UFO fender I have seen advertised is for a later year, will it fit? Can you buy OEM headlight assemblies, best place? Thanks.
The rear fender for a 1995 - 2006 KDX200 / 1997 - 2005 KDX220R will not fit a 1989 - 1994 model KDX200.
The OEM part is no longer available from a dealership. You might find one on eBay for a high price, but it will be much more than what an aftermarket complete headlight will cost. UFO, Polisport, Acerbis, etc. make them.
Polisport: https://www.rockymountainatvmc.com/part ... eadlight-p
Acerbis (AH-chair-bees): https://www.rockymountainatvmc.com/part ... eadlight-p
At 35 watts on the bulb, they should work on standard 1989 and newer KDX lighting. No. They won't light up the forest, even on high revs. :-)
92driver
Country: Australia
Post by 92driver »
so what are you using for an '89-'94 rear fender. thanks for your time.
oem
