Fork conversion or other options
sam the kdx man
Post by sam the kdx man »
Hi guys I have a 2004 Kdx220r. I weigh about 150 lbs. would I be better off for the money putting kx forks on, or just getting the stock ones re-valved and re-sprung? Looking to make the suspension stiffer and more nimble for a little bit of track usage but also keep it good in trails. Looking to get into hare scrambles this summer.
Has thanked: 190 times
Re: Fork conversion or other options
Hi. Welcome to kdxrider.net.
Have you read up on the KLX fork swap?
In general, I don't think putting that much money into the stock forks is a good way to go for someone who is looking to hit the MX track some and race a little out in the woods.
sam the kdx man
Haven’t read anything about it, only the kx swaps. I just got on this forum.
OK, thought you might have been reading some of the older threads.
KLX forks
KLX triple clamps
KLX brake hose (or homemade KDX hose run and mounting)
1995+ KDX wheel and axle are the same, I think
sam the kdx man
What are the benefits of klx forks over kx forks
avoiding a stem swap is the number one thing
otherwise, price and complexity
Been thanked: 55 times
The KLX forks are much stiffer (my biggest problem with the stock forks is the flex) and an easier fit. However, finding '96-'98 KX forks are fairly cheap and aren't that hard to fit. Do a stem swap, swap out springs and maybe shorten them internally, mount a KX wheel, and go riding. I will never ride on factory KDX forks again.
