Thinking of pulling the trigger on a EFM auto clutch.
When changing up do you just come off throttle and shift? And same down?
Auto clutches?
robkdx
robkdx
Re: Auto clutches?
I got mine used from another kdx owner on these forums. It was a simple “drop in” for the stock clutch. It comes with a spacer and longer case bolts. You’ll have to devise a way to seal off the hole where the OEM clutch mechanism goes there the top of the case. I used a bike and nut with appropriate washers and a rubber seal I cut from an old inner tube.
- G22inSC
Re: Auto clutches?
Rekluse here instead of EFM but as to your question, I still use the clutch for shifting gears.
'10 Honda Recon (wife's)
'08 Kaw KX65 (Sold)
'07 KTM 50SX Sr. (Sold)
'09 Yam PW50 (retired)
'97 Kaw KX250 (Sold)
Gallery
2005 KDX200 Bike Profile
'08 Kaw KX65 (Sold)
Gallery
robkdx
Re: Auto clutches?
EFM deletes the clutch so none to use.G22inSC wrote: 10:30 am Feb 09 2019 Rekluse here instead of EFM but as to your question, I still use the clutch for shifting gears.
