Inexpensive Parts Washer
ericr
Post by ericr »
For those of you starting a maintenance project, or a restoration, I found that a parts washer is indispensable.
After shopping and finding what's available, I found that a smaller one would fit my needs best. It holds up to 3 1/2 gallons of solvent and is small enough to fit on a counter next to a utility sink. I equipped it with with a flow-through cleaning brush and an immersible heater. All the items together was less than $100
Since I'm using a water-solvent, I immerse a heating coil into the solvent for a few minutes before adding my parts. This gets the temp up to as hot as I can stand while wearing gloves. The heat makes water-based solvent much more effective. I think it's as effective as stoddard solvent.
The solvent I use is Krud Kutter "Parts Washer" Cleaner/Degreaser available from Home Depot or Tractor Supply. It works great.
Here's a parts list of what I ordered from Amazon;
Re: Inexpensive Parts Washer
Cool. Thanks for sharing. I like the look of the brush.
I bought one of the 20-gallon Harbor Freight ones a few years ago. I HAD TO HAVE IT! I ended up never using it, and it was in the way for years. I finally sold it last year, thankfully. LOL
Tyl3r
Post by Tyl3r »
Nice, yea thanks for sharing. I have been thinking about one too. I used the one at my work a couple of times, its a nice heated industrial cleaner...its wicked convenient. Can't help but make me want a mini version for home :hmm: The parts list didn't come through for me. Would you mind posting it in text form or something?
ericr
Post by ericr »
Sure. Here's a text version;
Parts Washer - https://tinyurl.com/ydatv2a2
Hose and Brush - https://tinyurl.com/yb7lag8o
Immersion heater (I see this one is unavailable, but there's another high-wattage one) - https://tinyurl.com/y7o5fzo4
