Squish how who
Grobo
Country: U.K.
Squish how who
Post by Grobo »
Hello everyone
I’ve got a kdx220 with 35mm carb extended kips cover gnarly fmf the next thing I want to try is my squish.
Now living in England I can’t use the normal people so apart from the solder test what else do I need to know and does anyone know who to use in the UK
Cheers
cornishwrecker220
Re: Squish how who
Post by cornishwrecker220 »
Where in the UK are you ?
As you will be taking the head off they why not bite the bullet & send the head & jug off to be ported & matched ....there's a few good shops still in this country ..... I have a 36mm carb on my 220 & sent the motor to be "breathed" on ... Result was a 40hp tractor , docile when need be yet a ripper when you wated it to ! :supz:
Grobo
Country: U.K.
Re: Squish how who
Post by Grobo »
Sounds great, any shops that you can recommend
pumpguy
Been thanked: 2 times
Re: Squish how who
Post by pumpguy »
There are specialists in the UK catering to BSA Bantam racing. They have done some amazing things with these. They should be able to help you with head squish issues. IIRC Rex Caunt (sp?) is a name that comes to mind.
Grobo
Country: U.K.
Re: Squish how who
Post by Grobo »
just checked . IIRC Rex Caunt out and them seem more electronic ignition based
cornishwrecker220
Re: Squish how who
Where in the UK are you based ??
cornishwrecker220
Re: Squish how who
Check out Stan Stephens , he's been around for many years & specialises in tuning two strokes , he tuned my rd 350 lc & RG 500 back in the day with great results ..... There's also Mick Abbey tuning ....terry Beckett is another but not sure if he's around these days .
I used Gibbs performance ( just outside Plymouth ) ...he did a full engine rebuild ,port & head mod plus dyno set up for £500
Vossman
Re: Squish how who
Post by Vossman »
cornishwrecker220 wrote: 05:25 am Dec 08 2018 Where in the UK are you ?
That sounds like a killer ride.
Grobo
Country: U.K.
Re: Squish how who
Post by Grobo »
I’m in Blackpool, I’ve checked out Stan Stephens website and he’s sticking to rd now
Dan 250sr
Country: Japanese version
Re: Squish how who
Post by Dan 250sr »
Bdk race engineering ..Norfolk.. they do lots of two stroke stuff. They skimmed my head to adjust squish gap..mine is 1.40mm.. It was 2mm .. they have a website..
Has thanked: 193 times
Re: Squish how who
They make power valves for the 1989 - 1994 KDX200, too. (BDK Engineering)
Dan 250sr
Re: Squish how who
Post by Dan 250sr »
Just got my barrel back before x mas now 265 cc .. you tube kdx 250sr.. still haven't tried it. But bdk race carried out the work... they also sorted my crank out to accept kx barrel and piston.. A little bit slow. Or other option was kustom craft in USA.. would have loved there 310 mod....
