2005 kdx 200 making noise after water pump seal and bearing replacement
Firstinfire16
Replaced the both mechanical seals and bearing on the water pump, now it has a high pitched whine sound coming from the pump area as best I can tell. The sound increases with volume and frequency with increase of throttle. Clutch, tranny, and motor seem to be running fine. Any ideas?
- Molly's 70
- Been thanked: 3 times
Re: 2005 kdx 200 making noise after water pump seal and bearing replacement
Sounds like something is rubbing. I would take it back apart. Recheck your seal & bearing installation.
collkdx03
My kdx200 did that and it was bearing in the center of clutch basket
Cody wireman
did you figure the problem out? im having same issue
