Please please someone help with linkage
Scottkdx1980
Post by Scottkdx1980 »
Ok I have replaced bearings and all linkage bearings it’s a 1990 I looked at parts fiche but suspension is still stuck it seems like shock is striking that lil piece where those links bolts and reason being I should document when taking things apart lol someone snap a pic or 2 of how it goes or steer me down the right path lol it worked before I took it apart I never but should of took photo
Scottkdx1980
Re: Please please someone help with linkage
Has thanked: 6 times
Been thanked: 3 times
The bracket that is not bolted is on upside down.
rungrandpa
Country: U.S.A.
Has thanked: 1 time
Post by rungrandpa »
I have the same problem when I tried to replace my Kouba Link with standard link. If anything it should have had more clearance.
DoitDalton
Post by DoitDalton »
Here's a fully functional rear linkage on my 96'
What it looks like to me is your yoke is not bolted in the correct spot, should be connected via the bolt right above it's current location and like Molly said those brackets on the side are upside down.
Note my year of bike does not have those brackets, I'm not sure if it like that from factory or if the previous owner took them off, the point is you my not need them.Image
Sent from my moto g(6) using Tapatalk
Has thanked: 181 times
Been thanked: 46 times
The two holes go beside the engine case halves.
Look around the internet for some pictures.
Scottkdx1980
Thanks everyone it helped thank you now what is the routing for brake line and on chain side how do that guard hook on lol
