Greetings
Mordy
Country: South Africa
Greetings
Post by Mordy »
Hi there. My name is Rogan hailing from sunny South Africa.
Acquired a KDX200 2006 ripper earlier this year and have done a few out-rides, really enjoying the bike.
Recently had some bad luck with the bike, the clutch lever fell off so I had to order an OEM one from kawa and replace it.
I got a bunch of parts with the bike - o-ring chain, front and rear sprockets and then I bought a new clutch kit and took it in to be fitted and just have the bike mechanics do an inspection.
After all that was fitted turns out there is a weird issue with the gearbox, they suspect the shaft selector or drum (not really sure) might be damaged :sad:
Anyway I'll have the bike back soon and then I will do a few more upgrades and hopefully be hitting the trails next weekend!!
This forum is very useful and I am very glad I found it. To future adventures! :supz:
Rogan
Re: Greetings
Welcome to kdxrider.net.
Hopefully, it is something small.
Been thanked: 56 times
Greetings
Welcome! The KDX transmission is pretty tough so I would suspect it's something small.
Re: Greetings
Welcome, and good luck with the motor. How is parts availability in South Africa? Love to see some photos from your favorite ride areas.
Mordy
Re: Greetings
Post by Mordy »
Thanks Guys.
@SS109 Seems the selector spring is broken, hopefully I can source one soon.
@bufftester I will get some pics together and upload them. Most OEM parts are available from kawasaki at more or less the same rates in the US/EU etc. The selector spring is going to take a while to get here (has to be imported) so I am trying to source one locally. You can get most parts and we have local retailers that can sort stuff like carbs, top/low end kits and clutch kits so not too bad on parts availability.
Cheers!
Re: Greetings
Mordy wrote:@SS109 Seems the selector spring is broken, hopefully I can source one soon.
Same thing happened to me once. Glad it is a simple fix.
Mordy
Re: Greetings
Post by Mordy »
Yep, luckily. I trawled the web this evening and found someone selling off parts from a 99 kdx200, sent him the diagrams and asked if he has those springs (asked for both just in case) and he has them :supz: So will sort that tomorrow and hopefully be ready for the weekend!
