Transmission shift lever adjustment
Pda1122
Post by Pda1122 »
What’s the trick to adjusting the lever? I unscrewed the bottom bolt, pryed the coupler and hammered lightly to no avail. Is it a bad idea to spray wd40?
ScruffyDroid
Country: United Kingdom
Re: Transmission shift lever adjustment
Post by ScruffyDroid »
Remove it and then replace in your required position.
Sent from my SM-G930F using Tapatalk
Pda1122
Post by Pda1122 »
It’s stuck.
Has thanked: 193 times
Some lube would not hurt.
Are you able to see any gap when prying it apart?
kdx633
Post by kdx633 »
did you fully remove or just loosen the bolt?
Take the bolt all the way out or you risk damaging the knurling on the shift shaft. Then hit it with some penetrating oil and it should come off fairly easily. With the bolt out you can pry open the clamp easily far enough to get it off.
Careful spreading the “jaws” too much. You can crack the clamp right at the weld. No reliable repair for that.
Pda1122
Post by Pda1122 »
I was able to get it with lots of penetrating lube and patience. I can now feel comfortable with my new fly boots! Thank you very much!
Did you have boots before?
I was wondering why one would change the position.
Pda1122
Post by Pda1122 »
Didn’t use actual riding boots before
That is what I started thinking. You have to ride differently with boots on. It takes some getting used to.
