Idle and air/fuel not adjusting
Mav
Re: Idle and air/fuel not adjusting
Post by Mav »
That was my screw up. I was reading the optional parts list in the owners manual.
Mav
Post by Mav »
Quick update.
-Adjusted float to 18mm, it was WAY out of spec on the high side, probably about 22-24mm.
-Went down 1 size on the pilot and main jets
-Couldn't replace jet block gasket, because it had to be ordered
-Tried with air box lid and without, seems to run better with the lid
Made a little progress, it will idle a little longer before dying now but idle and air screws still do nothing.
Hopefully the jet block gasket comes in soon and that fixes the problem.
All other mechanics seem great, replacing fork seals today (they came in friday), new air filter, new protaper high bars (I'm 6'1"), finish coolant flush and fill with Engine Ice, change trans fluid, new chain, check front, rear, and triple tree bearings.
Also going to pull the jet block and see how the gasket looks
Mav
Post by Mav »
Also I think I might need a new float. The floor tab looks like someone may have damaged it, because the float adjustment tab is bent at a curve instead of being straight. Also last night I forgot to turn the fuel off and this morning i found a puddle of gas on the floor of my garage. If I knew how to upload pictures on here, I would since I have plenty.
Has thanked: 193 times
You can use a photo hosting service and link to them or supporting members can use the Gallery and attachments portion of the POST REPLY button (not quick reply section)
Mav
Post by Mav »
Ok. Thank you
Mav
Post by Mav »
Oh yeah, I also noticed the link for the online manual and went ahead and purchased the lifetime for it also.
Mav
Post by Mav »
Here is the bent float tab i was talking about.
The jet block gasket looks pretty flat
Mav
Post by Mav »
Also the parts guy at the small kawi dealer is an old KDX fan, he gave me 152 main and 48 pilot, that improved it some but still waiting on the jet block gasket to come in.
WOW!! That's a bad bend! :shock:
Mav
Post by Mav »
yeah that's what I thought too, but wanted to make sure it wasn't some kind of weird float. I'll order a new one and try to straighten this one out.
I would try to repair that one before ordering another one.
Mav
Post by Mav »
Will do. If I do need another though, it's only $16.65 on jetsrus, and my dealer beats any online price.
Mav
Post by Mav »
here is the crack in my rear rim
