brake hoses replacement
deepwoods
- Country: Norway
per the manual, the brake hoses should be replaced every 4 years , is that something that all you guys are doing?
, I have no trouble doing it but seems a touch much IMO
KDX 200, 2001 model
pumpguy
IMO, not so much a question of leakage or total failure, but actual braking action. If the hose is bulging out a little bit as pressure is applied, the braking action may be a little mushy.
For this reason, braided stainless steel brake lines are often advised.
- Has thanked: 10 times
- Been thanked: 12 times
I have never replaced a brake line unless I notice an issue with it like bulging or excessive wear.
- ICRage42
Re: brake hoses replacement
fyi nylon can wear to the inside and block flow without any indication of wear or physically looking effects. Making the caliper stick on or hang.
They are not made to last forever although most do. However they will break down in composition over time and contaminate the fluid. A general rule of thumb I follow is if its alright but over ten years old change it anyways.
- Has thanked: 50 times
- Been thanked: 17 times
Long time, no see. Welcome back.
