Does anyone know what type/size of puller I need to order to pull the flywheel?
Thanks,
1980 KDX175 Flywheel puller (??)
MotoFo
- Has thanked: 48 times
- Been thanked: 15 times
Re: 1980 KDX175 Flywheel puller (??)
Hi. I don't have my manual handy, but I imagine it is the kind that is a big plate with holes and bolts are threaded into the holes on the side.
If so, you can actually use a steering wheel puller with some washers and 6mm bolts. Also, there may be a need for a socket head bolt to thread into the crankshaft end to allow the big bolt to spin against. (greased top)
MotoFo
It worked on my '87. The 1989 and newer ones have a 27 mm x 1.0 mm left hand thread, but the older full sized air cooled ones don't have that one.
Just be sure to check the crankshaft end. Put a socket head bolt in there, then grease on the head to keep the puller from gouging the end of the crankshaft.
