what spark plug to use
garycrafton
Country: UNITED STATES
Post by garycrafton »
any one have input as weather to use a iridium plug or not ? not sure if it will hurt ,,over heat the cylinder ,,??
I have a 1998 kdx 220r,,i run amsoil at 100 to 1 ratio always use 91 octane pure gas
6 Riders
Re: what spark plug to use
Post by 6 Riders »
garycrafton wrote:any one have input as weather to use a iridium plug or not ? not sure if it will hurt ,,over heat the cylinder ,,??
Just use the standard plug, they burn just fine.
STD plug is fine.
100:1 huh? Is that the Amsoil recommended ratio for that oil?
Has thanked: 116 times
Been thanked: 31 times
100:1 and you are worried about a plug?? LOL
Like everyone else, I am wondering why 100:1? What kind of riding do you do?
Has thanked: 1 time
Been thanked: 3 times
I know Amsoil makes a 100:1 2 stroke oil, but not for motorcycles like ours. I still use the Amsoil 50:1 oil for my KDX. I also use their oil in my truck.
spl383
Post by spl383 »
Amsoil saber is the only one rated at 100:1 and it is for SABER Professional is specifically designed for handheld pre-mix two-stroke power equipment including, but not limited to, chainsaws, trimmers, blowers, brush cutters, edgers and shredder vacs.
I run amsoil intercepter at 50:1
Spark Plug is NGK BR8ES
garycrafton
doakley wrote:STD plug is fine.
,,,,yes it is ,,and it runs much cooler than before ,,i will never use anything but amsoil
I thought 100 to 1 was crazy too,, no over heating no fouled plugs ,,ever ! ,,was just wondering if the iridium plug was
a good idea or not
garycrafton
spl383 wrote:Amsoil saber is the only one rated at 100:1 and it is for SABER Professional is specifically designed for handheld pre-mix two-stroke power equipment including, but not limited to, chainsaws, trimmers, blowers, brush cutters, edgers and shredder vacs.
I can up the mix to 50:1 but ,,ive been running it at 100:1 for like 10 years now with no problems at all ,,amsoil dealer says it was really tested at 200:1 but they thought no one would ever believe that so they market it at 100:1,,anyway ill up it a little to like 80:1 ,and yes it is the saber I use
garycrafton
we did not like the interceptor seemed to make the bikes run higher temp using inferred temp gauge ,,maybe I need to do a little more digging in to this
garycrafton
garycrafton
does say its good for snowmobils there like 600cc motors ?? ??/ just don't know
garycrafton
Jason wrote:100:1 and you are worried about a plug?? LOL
trail riding ,,and yes 100:1 and have for like 10 years and never one problem ,,runs cool does not foul plugs ,,,,,seems to work and work well ,,got the idea from an amsoil dealer ,,and like I said I ride a 1998 kdx 220 and have had a few of them and never had ring or cylinder fail .,,,right or wrong does great ,,matter o fact got my two buds using the same ,,on a 2001 yz 250 and a 1990 cr 250 no problem there either ,,LOL !!!
BR8EIX or BR8ECMIX
