1990 kdx200 project
javjacob
1990 kdx200 project
Post by javjacob »
I bought a 1990 KDX200 for $300. Seller said it doesn't run but when I turned the motor over fuel was coming out the head gasket and dripping pretty bad. I also noticed 1 of the nuts on the head was missing where it was leaking.
My brother is buying it off me and is excited to get it running. Its fairly roached but definitely has potential. It was missing the rear brake caliper so I bought one off EBay for $38 and I already have a rear brake hose.
Going to pull the head and check out the piston and cylinder when the temps get decent outside. Hoping to have this bike running good soon.
Is the cylinder on these plated?
2000 Kawasaki KDX220R
1996 Kawasaki KDX200
Has thanked: 160 times
Been thanked: 40 times
Re: 1990 kdx200 project
If I may suggest an option, don't spend another penny on anything besides the engine. If it won't run, then there is no need to stop the motorcycle.
In stock form, the cylinder was plated when new. Did someone have a sleeve installed in the last 28 years of ownership? You will know when you open it up and look.
Good luck, and I wish you patience and money. It will take a lot of both to get it in proper shape.
javjacob
Post by javjacob »
I agree, the plan is to get it running first. If its not worth saving it can be parted out I suppose.
javjacob
Post by javjacob »
Is the carb a 35 PWK the same as the 95-06 200?
david
Country: UNITED STATES
Post by david »
Yes, but jetting and needle is different between the two
'81 KDX 175
'90 KDX 200
'82 Honda GL500 (sold)
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
It is not the exact same version, but they are both PWK35.
javjacob
Post by javjacob »
ok thanks, I know a lot about the H series but new to the E series. haven't messed with it since its been so cold.
javjacob wrote:ok thanks, I know a lot about the H series but new to the E series. haven't messed with it since its been so cold.
Global warming got you, too? :snooty: :neutral:
javjacob
Post by javjacob »
Yeah lol it was 17 below zero the other night.
17 below zero??
You people kill me. No way for this Alabama boy. It is 25 here at 7 AM Central time. It needs to warm up!!
Has thanked: 30 times
Been thanked: 47 times
1990 kdx200 project
I don't know what you guys are talking about. :hmm: Weather has been great! Supposed to be mid-70's today. :mrgreen:
I hope a tumbleweed rolls into you while you are putting on sunblock. :razz:
javjacob
1990 kdx200 project
Post by javjacob »
Our cold spell finally passed by, its in the 50's today.
I got the new head gasket on and everything torqued to spec. When I had the head off I noticed the crankcase was full of premix so I layed the bike on its side and kicked it over several times while it puked out a flood of gas. I turned the fuel petcock on then back to off and tried kicking it over and it started pouring fuel out of the cylinder/pipe after a handful of kicks. Apparently the petcock valve isnt shutting the fuel off and im not sure how the carb can be letting that much fuel into the motor. I kicked it over one more time and it started pouring fuel out instantly. The fuel isnt dripping its a couple of steady streams pouring onto the floor. Headaches!!! It does have spark though.
1990 kdx200 project
If it's just pouring through then the float on the carb is stuck open. Time to to pull it off.
javjacob
Post by javjacob »
I will be removing the carb when I get the chance. The intake will get a good cleaning while I'm at it and check the reeds.
I don't know if the reeds' gap is correct or if they are frayed or chipped, but it sounds like they are well rinsed. :mrgreen:
javjacob
1990 kdx200 project
Post by javjacob »
Finally got it running and fixed a few things that needed fixed. Bike runs good and have just under $500 invested.
1990 kdx200 project
javjacob wrote:Finally got it running and fixed a few things that needed fixed. Bike runs good and have just under $500 invested.
For now. :lol: All dirt bikes are money pits. We shovel all day and can never dig ourselves out of the hole. :doh: :hmm:
javjacob
Post by javjacob »
Yes they can be but its a 2 stroke so it wont ever be as bad of a money pit as a 4 stroke.
