Super moto rims. On 03 kdx 220r?
Curbdogjr
Post by Curbdogjr »
I've been searching (I've read 2 threads I could find on here) but I want to know if I can just get the rims (front and back 36 spoke)
4.25 rear
3.50 front
http://www.warp9racing.com/product/sm-rims/
and spokes. Would I be able to simply relace the rim to my stock hub? Front and back? Or would I have to go and do the front fork conversion to a kx model? Thank you in advance.
-SkylarImage
Sent from my SM-G930T using Tapatalk
Curbdogjr
Re: Super moto rims. On 03 kdx 220r?
Post by Curbdogjr »
Edit: pic is what im aiming for.
Tyl3r
Post by Tyl3r »
I was looking into this in the past as well. Supposedly you can lace the rim right to the stock hub using a supermoto spoke kit. I can't exactly confirm this, but that was the impression that I was under when I was researching. Also, check out MotoX Industries for supermoto stuff: https://motoxindustries.com/product-cat ... o/sm-rims/
Also, I'm not 100% sure on the proper rim widths to use. thirdgenlxi will likely chime in (hopefully lol). I was talking to him about the sumo wheels before. I can't remember how wide his rear rim is, but he cautioned at going too wide because the chain will rub your tire. Just something to keep in mind.
Has thanked: 116 times
Been thanked: 31 times
Hello. Welcome to the forums.
s10gto
Post by s10gto »
+1 for motoxindistries. Call and talk to Jim. Super helpful guy. He can get you set up right.
Curbdogjr
Post by Curbdogjr »
Tyl3r wrote:I was looking into this in the past as well. Supposedly you can lace the rim right to the stock hub using a supermoto spoke kit. I can't exactly confirm this, but that was the impression that I was under when I was researching. Also, check out MotoX Industries for supermoto stuff: https://motoxindustries.com/product-cat ... o/sm-rims/
Thank you so much! I was hoping for this news! I'll likeley be doing this in a few months and will post my further discoveries as I go! Thanks again![emoji16] [emoji16] [emoji16] [emoji16]
Curbdogjr
Post by Curbdogjr »
Jason wrote:Hello. Welcome to the forums.
Thank you!
Curbdogjr
Post by Curbdogjr »
s10gto wrote:+1 for motoxindistries. Call and talk to Jim. Super helpful guy. He can get you set up right.
Sweet! I'll do that thank you!
Curbdogjr
Post by Curbdogjr »
Hey guys just got a message back from warp 9 and they said they couldn't supply spokes that would work for me, BUT they gave me the name of a place in CA that does custom spoke set ups if you send in your hub! So in case anyone wanted to know in the future.
http://www.buchananspokes.com/
Thank you for your help guys and I'll post up somthing when I have completed all of this project! Again thank you guys!
2stroketim
Country: Usa
Post by 2stroketim »
3.5 4.25 ... my chain might still just touch, stock hubs from a kx... front forks to 97 kx... you can use kx hubs with a Kdx and different spacers I laced mine with warp 9 rims nipples and spokes... there not perfect but I think just need to set a bit and be re trued...I'm almost done now... doing the lighting with a tusk kit to run the signals and horn and an 85 watt Ricky stator to run the tail light and headlight
