From left to right: Wiseco, OEM, Pro-X
What is the function of the large ports? Note that the Wiseco has small round ports while the OEM and Pro-X have large blocky ports.
From the bottom, note that the Wiseco has a single hole for the piston pin lube, while the other two have two holes. I would think that two would be better than one, but maybe the single hole in the middle is stronger and puts oil on the pin better? Or maybe it doesn't make any difference?
Any other comments on the pistons? The Pro-X is obviously new, the OEM was used for a single AX season, and the owner of the Wiseco used Bel Ray MC-1 at 50:1. When I put a new ring on the current piston, it was very clean- looked like the Wiseco with the OEM top.
The reason I'm asking all this is because I've been using OEM and Pro-X in my KDX and going thru the perennial personal debate about "Which piston to use?" I'll probably stick with Pro-X. But I'm curious about the difference in the ports.
