jimmy97
Posts: 42 Joined: 03:20 am Apr 04 2009
Post
by jimmy97 » 12:01 pm Aug 16 2017
does this look right to anybody? this is at tdc .
Sent from my VS985 4G using Tapatalk
Posts: 6257 Joined: 05:11 am Aug 23 2009
Has thanked: 33 times
Been thanked: 57 times
Post
by ss109 » 03:36 pm Aug 16 2017
I assume your asking about the piston to deck difference? It looks deeper in the hole than I have seen. Does it have two base gaskets on there or an extra thick one?
jimmy97
Post
by jimmy97 » 06:03 pm Aug 16 2017
it actually has no base gasket on it in this picture
jimmy97
Post
by jimmy97 » 06:13 pm Aug 16 2017
I have rebuilt many 2 strokes in my day. and have never seen a piston this far in the hole at tdc. don't get me wrong, this bike rips! this just looked a little off to me.
Vossman
Posts: 262 Joined: 06:23 pm Jul 24 2017
Post
by Vossman » 06:21 pm Aug 16 2017
Keep us posted on what you figure out. Never see one that low.
Heres my old YZ motor.
pumpguy
Posts: 840 Joined: 10:00 am May 29 2012
Been thanked: 2 times
Post
by pumpguy » 09:42 am Aug 17 2017
Maybe someone put in the wrong piston or con rod. Did you happen to check the compression pressure before the head came off?
Is the piston crown this low @ BDC below the bottom of the exhaust and transfer ports?
cornishwrecker220
Posts: 743 Joined: 06:37 am Nov 22 2009
Post
by cornishwrecker220 » 10:25 am Aug 17 2017
It's quite normal for there to be a gap .... I'm sure if you placed a ruler across the top of your piston it would be level with the top of the jug .... It also has to accommodate expansion .
Posts: 14749 Joined: 06:45 am Nov 01 2004
Has thanked: 193 times
Been thanked: 48 times
Post
by KDXGarage » 10:32 am Aug 17 2017
Solder for squish measurement time??
jimmy97
Post
by jimmy97 » 11:07 am Aug 17 2017
squish without head gasket. . . . 148 thou , plus .010 for head gasket for a total of 158 thou or 4.013 mm
jimmy97
Post
by jimmy97 » 11:32 am Aug 17 2017
uh, yeah. Just looked it up , I'm about .100" over ! Lets start from the beginning.
I bought this bike for next to nothing, case was split due to a blown output shaft bearing (the one behind the front sprocket) guy said everything was there. well the crank and clutch was missing. no biggie. purchased a used crank off eBay along with a new rod and bearings sent this to RB to have it assembled, since he was doing my head and carb anyways. never had a chance to compare crank nor rod side by side so it looks like a wrong part was put in. piston is a stock piece. I guess this means I can run 87 octane has then ! I've been riding this bike for about 2 years this way. it runs good. I just gotta spin in like a 125 . oh well. I'm still gonna send it !
jimmy97
Post
by jimmy97 » 11:34 am Aug 17 2017
this is piston at bdc
jimmy97
Post
by jimmy97 » 11:36 am Aug 17 2017
jimmy97 wrote: this is piston at bdc
see pic
jimmy97
Post
by jimmy97 » 11:38 am Aug 17 2017
jimmy97 wrote: jimmy97 wrote: this is piston at bdc
see pic
unless anybody has any advice before I re-assemble?
jimmy97
Post
by jimmy97 » 12:16 pm Aug 17 2017
stroke is measuring right at 58 mm. it looks like the only thing it could be is the wrong length con rod was installed
jimmy97
Post
by jimmy97 » 12:42 pm Aug 17 2017
this is the exact rod that is in my bike now. looks like I was in a hurry and ordered the wrong year rod
Post
by KDXGarage » 02:26 pm Aug 17 2017
If it is too short, how do you have proper compression?
Congratulations on your bravery and fearlessness to run a $49 connecting rod kit.
pumpguy
Post
by pumpguy » 02:27 pm Aug 17 2017
Wrong rod could be the problem. OEM rod # 13032-1210 is only listed for '95 & later H Series 200 & 220.
Looks like old man Murphy strikes again
david
Posts: 524 Joined: 08:30 pm Oct 10 2011
Country: UNITED STATES
Post
by david » 02:32 pm Aug 17 2017
'81 KDX 175
'90 KDX 200
'82 Honda GL500 (sold)
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
Post
by KDXGarage » 02:56 pm Aug 17 2017
following photo from phospher site (good job to him!)
Since you gave about zero background info, did you just install the rod kit? What have you JUST done and how did it get to the point in the picture? Thanks.
Vossman
Post
by Vossman » 07:38 pm Aug 17 2017
Cool you got it figured out.
