The '95 KDX200 needs a new clutch. I know you're supposed to soak clutch disks in oil overnight before you install them, but I run ATF type F in my bike. So, my question is, do I need to soak them in ATF overnight or should I just soak them in normal motor oil? Thanks for your time.
Sent from my ONE A2005 using Tapatalk
Soak Clutch Disks in ATF?
bergilong
- ss109
- Has thanked: 30 times
- Been thanked: 44 times
Always soak them in the type of oil you plan to run which, in your case, that would be ATF.
bergilong
