Problem after problem..
Jim B
Re: Problem after problem..
Any chance the front sprocket is spinning on the countershaft? (Splines on one or both are ruined?)
- ss109
- Has thanked: 30 times
Yeah, that's one that totally slipped my mind, oil type. What are you using Scrandy? Maybe drain it out and try some ATF Type F or even Dextron/Mercon Type III.Jim B wrote:What are you using for gear oil? Apparently, 'Energy Conserving' motor oil can cause wet clutches to slip. (I'm assuming you have that standard, or an equivalent, in Canada.)
I can't think of much (anything, really) that it would be besides the clutch and/or the chain and sprockets.
Scrandy
I'm am running Klondike atf without a friction modifier. I checked before I put it in.
2004 KDX220R. I'm Canadian eh.
- ss109
That's a full synthetic, correct? If so, that could be the problem. I know some bikes and some synthetics don't play nice together.
Scrandy
I'm not sure it dosnt say anywheres. I just checked for a friction modifier which it dosn't have. Same stuff I always ran before with no issues. Actually on my old clutch the first time I changed the oil after I bought the bike I accidentally put in an atf with a friction modifier because I didn't see it listed on the bottle until I seen the bottle laying around about 2 weeks later and checked it again and realized. so I changed it after that. It actually ran fine with that stuff. Anyways long story short the fluid that I switched to after that never gave me problems.
- Been thanked: 10 times
If you used the EBC springs did you check them for proper length first? The last EBC clutch kit I got the springs were 2 mm short which made them unusable, had to order a set of OEM springs separately.
Scrandy
No I didn't. What would stock length be? I'd check mine but god knows how old they are.
IIRC spring free length should be around 36mm, with friction plates at 3mm and steel plates 1.6mm....or that might be for the E model...would have to check the service manual.
Scrandy
- ss109
H-series free spring length should be 38.7mm with service limit at 37.2mm. BTW, end of clutch lever play should be between 10-20mm.
- Tedh98
- Been thanked: 2 times
That is like a carpenter without a hammer.Scrandy wrote:A service manual is something I don't have.
You really should get one before you do anything else.
