Of course, pulling more cable will further scrunch the clutch springs. I don't know what the coil bind spec is on the KDX. I'm saying 'more' is not always 'better'. The noted lever evidently doesn't have that problem...so...peaches!NM KDX200 wrote:My bike used to creep with the lever in, but I got an MRS Raptor and it pulls more cable- problem solved.
Taking notches out helps..give the plates someplace to move TO when the pressure is off.
The KDX commonly has some creep problems. Engine off and in gear, pull the clutch and try to push it. Ugh!!
