Help w/1985 KDX200?
TigerKDX200
Help w/1985 KDX200?
Post by TigerKDX200 »
Issue> stall at idle & sputter at low RPM, runs smooth in upper range
Troubleshooting & Results>
1. ran compression test & was near bottom of operating range (122 psi), installed used rings off eBay & got modest improvement in compression (133 psi)
2. thoroughly cleaned carb & installed new jets (stock size), needle is good, float/needle good
3. thoroughly cleaned air box & installed new filter
4. installed new plug
5. examined piston & cylinder, no significant wear
6. examined reed block/reeds, no issues
7. checked for air inleakage on intake side found nothing wrong
8. found exhaust gasket/rings degraded/gone so it has moderate exhaust leak between head & pipe (ordered parts...TBD after install if that helps issue)
Any suggestions what else can cause the stall/studder issue??
Thanks!
6 Riders
Re: Help w/1985 KDX200?
Post by 6 Riders »
Did you replace the pilot jet?
Other things to look at are float height, throttle cable, petcock and vent tubes.
Sent from my KIW-L24 using Tapatalk
TigerKDX200
Help w/1985 KDX200?
Replaced pilot jet, replaced petcock, installed new fuel lines, removed & lubricated throttle cable. Did not check vent tubing, from memory there are 2 lines....will pull those & check. Not sure about float height, it's not adjustable that I can tell; no bendable tang like on my CRF450R. My exhaust gssket/O-rings arrive tomorrow as well. Thanks for tips, I'll keep chasing till it's solved.
david
Country: UNITED STATES
Post by david »
Never seen a non-adjustable float.
'81 KDX 175
'90 KDX 200
'82 Honda GL500 (sold)
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
G22inSC
Post by G22inSC »
Can't wait to see this one once you get it sorted out!
'10 Honda Recon (wife's)
'08 Kaw KX65 (Sold)
'07 KTM 50SX Sr. (Sold)
'09 Yam PW50 (retired)
'97 Kaw KX250 (Sold)
Gallery
2005 KDX200 Bike Profile
KDX Geoff
Help w/1985 KDX200?
Post by KDX Geoff »
To eliminate the carb as the issue, fit a carb of another bike and see what it's like.
1980 KDX400-A2
Help w/1985 KDX200?
Post by 1980 KDX400-A2 »
... installed used rings ...
Why used?
David
G22inSC
Post by G22inSC »
Why used?
Because that's all he could locate as OE rings (and aftermarket) are no longer produced.
'08 Kaw KX65 (Sold)
Gallery
6 Riders
Post by 6 Riders »
I could be completely wrong, but it would seem to me that newer kdx rings would work. The bore and design should be similar, no?
Has thanked: 159 times
Been thanked: 39 times
The ring end shape may be different? Different ID? ring actually thicker, taller??
G22inSC
Post by G22inSC »
6 Riders wrote:I could be completely wrong, but it would seem to me that newer kdx rings would work. The bore and design should be similar, no?
That's what I originally thought as well. I'll let TigerKDX200 ring in with the details but long story short, he spoke with a Wiseco individual who stated it would not work and gave specific details of why and the current options available.
'08 Kaw KX65 (Sold)
Gallery
