No compression 97 kdx200
- G22inSC
I believe that time frame just went out the window. I would bet a paycheck it's going to need a replate (piston and rings are a given). May as well do a complete bottom end based on the condition of everything else at this point. That IS an abused bike.
'10 Honda Recon (wife's)
'08 Kaw KX65 (Sold)
'07 KTM 50SX Sr. (Sold)
'09 Yam PW50 (retired)
'97 Kaw KX250 (Sold)
Gallery
2005 KDX200 Bike Profile
'08 Kaw KX65 (Sold)
Gallery
IceCold4x4
Re: No compression 97 kdx200
Yup I think that cylinder is going to need to be shipped somewhere. Recommendations?
1997 KDX 200 - FMF pipe and silencer and I have no clue what else yet.
2000 ZRX1100 - 1109 big bore, ZX11 carbs / cams/ double valve springs / igntion box / Kerker exhaust. It's Mad Max black and fast but rarely clean
2006 Volvo XC90 V8 - The toy hauler and sleeper. 300hp and AWD in a soccer mom SUV.
- 6 Riders
Millennium Technologies did mine. You need to buy a piston and send it with, or buy on from them, so that it can be matched. You also need to pull the studs (and replace the rusty ones), or they charge you to do that (it might be a good idea to let them do it) and remove the kips parts.
IceCold4x4
6 Riders wrote:Millennium Technologies did mine. You need to buy a piston and send it with, or buy on from them, so that it can be matched. You also need to pull the studs (and replace the rusty ones), or they charge you to do that (it might be a good idea to let them do it) and remove the kips parts.
how would i know how big of a piston to buy those scratches seem pretty deep above the exhaust port.
- 6 Riders
Go stock. They'll Nickel seal it back to stock size, welding up anything that is to deep to "just seal" over.
Link http://www.millennium-tech.net/serviceInfo.php?id=1
IceCold4x4
What about jumping up to millennium's 225 kit? i mean heck more power right?6 Riders wrote:Go stock. They'll Nickel seal it back to stock size, welding up anything that is to deep to "just seal" over.
- 6 Riders
Yes sir, if you have the money! I am reading about it right now......Might as well.
- 6 Riders
If I'm reading that price right....Might as well, since you're looking at that much to do the same thing for stock size.
IceCold4x4
good thing the state of alabama owes me 500 bucks for a tax refund.... shhh don't tell my wife lol my biggest fear is one day she sells my stuff for what i said i paid...6 Riders wrote:If I'm reading that price right....Might as well, since you're looking at that much to do the same thing for stock size.
IceCold4x4
ya i'm wondering if that's still the stock piston, and also how many hours are on it....
https://youtu.be/N-Wd6nnwO74
[youtube][/youtube]
[youtube][/youtube]
pumpguy
- Been thanked: 2 times
For lower end bearing wear, side - to - side play can be misleading. You really need to measure the up and down play.
The manual calls for a radial clearance of 0.026 - 0.043 mm (.0009 - .0017 inches). The service limit listed is 0.10 mm (.004 inches) IMO, that service limit for the lower end rod bearing IS A LOT; for me too much.
To measure this up and down play, I would try to rig up a dial indicator and see what the numbers really are. Maybe you could clamp the indicator to one of the cylinder base studs.
Regarding the bore size, you really should measure the bore diameter. This will tell you if you have a stock bore or something oversize.
Stock bore for an H series KDX measures 66.026 - 66.041 mm.
Hope this helps. Good luck.
IceCold4x4
The up down play is in the neighborhood of tolerance for a turbo compressor, and tighter than a 50cc Honda valve. It's at the i think I can perceive some movement but meh?
I'll have to check it.
- 6 Riders
That piston is HAMMERED! Yes it looks like a stock piston, can't say if it's the original or not though.
IceCold4x4
Says made in Japan lol I'm guessing it is.
javjacob
That piston doesn't even resemble a piston lol. Send the cylinder to Millennium, can do a 225 bore and replate. Get your new piston first so you can send it in with the cylinder to be on the safe side.
Looks like a good candidate for a frame up rebuild. If you get the frame Powdercoated, replace some bearings and new plastics you will have a really good looking bike.
2000 Kawasaki KDX220R
1996 Kawasaki KDX200
- Has thanked: 161 times
- Been thanked: 40 times
Powdercoat? That might integrate with this weekend's ride.
Have you tried muriatic acid on the cylinder walls to get the aluminum off, maybe to get a better idea of exactly how bad it is?
IceCold4x4
Not yet. Been working like a mad man to get more money to pay for this habit lol
Ha! Good luck. Dirty bikes are our favorite money pit.
