wossner
deepwoods
Country: Norway
wossner
Post by deepwoods »
hello, i am looking into getting a wossner piston for my 01 kdx 200,but they come in 66,00, 01,02mm a ,b ,c what to get?my bike has probably 50 to 100 hours on it, thanks
KDX 200, 2001 model
ced64k
Re: wossner
Post by ced64k »
Hi, go to your local shop to have your cylinder measured. A special tool is required.
deepwoods
Country: Norway
Re: wossner
Post by deepwoods »
does anybody in here have a wossner piston in their 200, and which one , and how is it working out ? and does it come with rings and pin, clips or the bare piston alone? thanks
KDX 200, 2001 model
Re: wossner
Stock bore is 66.0 mm. IIRC the difference between the A, B anc C is .01mm so A=66.00, B=66.01 and C=66.02. Get your cylinder measured as mentioned, most mechanics I know just use B pistons (I'm sure it is some old school reasoning involved but idk). I have used them in my jet ski and it came as just a piston, had to rder rings and pin separately, but that was a while ago. Wiseco is well known in the KDX world and what I'd guess most people running non-OEM have installed. I have about 250 hours on my Wiseco with no issues.
deepwoods
Country: Norway
Re: wossner
Post by deepwoods »
thanks, and the odometer on the bike, first digit is? from norway, not used to miles. we use km. i have a odometer that says only miles
KDX 200, 2001 model
Re: wossner
1/10 of a mile
deepwoods
Country: Norway
Re: wossner
Post by deepwoods »
so when it says 336 i have rode 336 miles? it doesn't go further than 999. when its says 010 it means 1 mile?
KDX 200, 2001 model
Re: wossner
Is the first digit a diferent color? From what I remember on my original odometer, the rightmost digit was black on a white background and wa tenths of a mile, the other digits to the left were white on a black background and were miles. so 336 would have been 33.6 miles and 010 would be 1 mile.
deepwoods
Country: Norway
Re: wossner
Post by deepwoods »
yes it looks like that one, it a usa bike, got imported from usa to norway, kan i get a km meter and just replace it with?
KDX 200, 2001 model
Re: wossner
Not that I know of, the OEM unit is a direct cable drive. You could replace it with an aftermarket one like a TrailTech. Here in the states it was one of the first things that usually got broken and was too expensive to replace so mot folks I know just never worried about it. Maybe some of the other overseas guys can chime in.
Has thanked: 179 times
Been thanked: 46 times
Re: wossner
MOVED from "Ask the Moderator" to the general Q&A forum.
If you are asking about getting an OEM Km unit, then I think you can. Check the odometer drive sending unit to make sure the part numbers are the same. There is a gear in there, but hopefully it is the same. The "cable" is technically a square, flexible rod.
deepwoods
Country: Norway
Re: wossner
Post by deepwoods »
only the last digit is white, the 2 in the front are black, so if it says for ex 300 is that 30,0 miles? and one mile is about 1600 meters? or 1,6km?
KDX 200, 2001 model
Re: wossner
Yes. The last digit is the tenths.
deepwoods
Country: Norway
Re: wossner
Post by deepwoods »
thanks jason. but can anyone tell me if the 8093db wossner is a good choice for my 01kdx 200? sound 100 hours.
KDX 200, 2001 model
Re: wossner
I have hread several posts from Wossner piston owners saying they thought it was a VERY good piston. I would not avoid it as a choice. I think Namura is the only piston I have heard bad mouthed often.
ScruffyDroid
Country: United Kingdom
Re: wossner
Post by ScruffyDroid »
I have just replaced the stock piston in my 02 220R with a Wossner. Came with the wrist pin, two rings and circlips. The the UK and Europe, in general, they are more readily available and cheaper than Wiseco.
So far so good. Not heard any bad reports about them.
deepwoods
Country: Norway
Re: wossner
Post by deepwoods »
thanks jason and scruffy, but do you guys think that since my bike has run about 100 hours the B piston is the right choice? 8093db is the name. last letter indicates the size, even if its bugger all difference in size. if some one who has put the B PISTON WOSSNER in their 200 would chime in it would be great!
KDX 200, 2001 model
ScruffyDroid
Re: wossner
Mine has the A piston in. Standard size.
Re: wossner
If you are wanting the piston clearance to match up just right, you are going to have to take the piston and cylinder to a machine shp, motorcyle shop or have high dollar tools yourself.
deepwoods
Country: Norway
Re: wossner
Post by deepwoods »
yeah i know jason, just wanted to bypass the trouble, on a side note , does any one know how much a new kdx 200 h cylinder costs?
KDX 200, 2001 model
