rear spoke question
towpro
- Country: usa
rear spoke question
Picked up 91 kdx 200 so I can go trail riding again. I know the bike, know the history, its really in pretty nice shape, but I ran into a problem with the rear rim.
About every 4th or 6th spoke is loose, some on both sides of wheel. Wiggle in the rim type loose. Since I am a heaver rider I need to get after this before I put it back on the trail.
Do I try one at a time to free up the loose spokes in nipples, run the nipple all the way off, brush it, apply anti seize, than try to torque it back (around 15" lbs I think I read), doing one at a time?
or should I just spend the $100 bucks and buy a complete set?
if I do the complete set, how do I do it without screwing up the wheel alignment? right now everything is still straight.
My guess is cut out 1 loose spoke at a time, replace it, then torque it to specs, then do another loose on other side, as well as other 1/2 of wheel.
after all the loose ones are done, start on cutting out one tight one at a time, and proceed as above.
- Has thanked: 194 times
- Been thanked: 49 times
Re: rear spoke question
Try to see how many you can loosen.
I doubt you will have much success on trying to snug them all the way down one at a time.
- Been thanked: 10 times
If it's every 4-6 you're only talking about 6-8 spokes. I would just work the loose ones, one at a time. No need to relace a straight rim for a few loose spokes.
towpro
- Country: usa
rear spoke question
I am also looking for a rim lock. and in case I do buy some spokes in aftermarket,
am I correct in reading that 88-94 was 1.85 x 18 rear rim, and 95-2006 was 2.15 x 18?
Thanks
Thanks
You can get a Motion Pro or other brand rim lock.
1989 - 1994 came with a 1.85" rear rim and 1995+ was 2.15". I don't think that would change the spoke, though. Look on the parts diagrams for your bike. Kawasaki sells the spokes and nipples individually.
towpro
- Country: usa
rear spoke question
I think I counted 10 total, some on both sides of rim. I just was able to free up 3 out of 4 I tries so far and clean them, antisense application and now I could tighten them up enough.
than I snapped off the 4th one. so at that rate, if i need to buy 3 or 4 from dealer that will not break the bank.
sure hope the vice grip marks on spoke are not causing a weak spot, but the one that broke did break inside the nipple. I should have done a little more back and forth instead of back and back
Are you using penetrating oil and letting it set?
towpro
- Country: usa
Yes. Been sitting, spray some more, sit some more. I can't work on again until Thursday, but I will keep spraying them until then
- Tyl3r
On a set of wheels that old, who knows the integrity of the spokes? Especially if you are having problems with them here and there. What happens when you fix a couple, put the tire back on, go out for a ride, then two or three more are messed up... then take the tire off again, replace those ones, put the tire back on, go ride, find two or three more bad ones... when will it end? lol
If you have access to a truing stand (or don't mind buying/building one) and want the piece of mind, just rebuild them. Its really not that bad. I physched myself out for a while... and then I watched a bunch of youtubes, borrowed a stand and rebuilt my wheels. Not too hard at all, especially if you have a dial indicator handy to check your work (just takes a lil bit of time). One wheel should be less than 100 bucks in parts, and when you are done, its something else you don't have to worry about. Older spokes will fatigue over time and won't want to stay torqued, My vote is for a rebuild!
I vote for taking the tire off, put penetrating oil on ALL spoke ends and spoke nipples, loosen all that will loosen, then replace the ones that don't work
towpro
- Country: usa
Tire is already off, right now bike is on lift and wheel is sitting in swing arm. I do have all the stand/ dial indicator I need, just waiting to get feeling better from this cold I got. Mean time still soaking spokes from both ends on nipples
- Tyl3r
Good luck! I don't have the patience for that lol I'd have cut them all off already and had new ones on order.
towpro
- Country: usa
I will be moving before long on this project again. Doctor said bronchitis, and gave me Zpack. Maybe it started with the dirt I inhaled when I took the wire wheel to the inside of the rim
Hate to hear that. Get well soon.
Dust masks, 20 for $3 at Wal-Mart. Gotta wear em.
towpro
- Country: usa
rear spoke question
all loose spokes are now free. I need to buy 2.
looking on line i see this:
SPOKE-INNER,RR,189MMX160D
41029-1199
quantity shows 36, which I assume means 36 spokes, so can I assume both left and right are the same spoke?
NIPPLE-SPOKE
41032-1061
so spokes on rear rim are the same left and right? dealer wants $11 for one spoke and nipple, but by the time I pay shipping online its close.
41029-1199
NIPPLE-SPOKE
41032-1061
Yes, rear spokes same length on all. Front has different inner/outer lengths.
As bufftester stated, all the rear spokes on that bike are the same length, inner and outer, left and right. All 72 nipples are the same.
I think I must say, $22 and some learning wins out over buying a whole new set and completely building a wheel.
- Tyl3r
Can't say it has won out yet! Need some riding time to see if any of the other 25 year old spokes give an issue lol I hope they don't, but its hard to say...
Ain't everybody big ballin, pick up the phone and get it done like you.
towpro
- Country: usa
my nasty cold is going away, but I screwed up and did not order enough spokes (long story). another week delay now, but its only Feb, got plenty of time.
