plastic fuel tank
capnbluetootharr
plastic fuel tank
Do the E series plastic gas tanks fit on the 200 sr models with the oil tank removed?
Dodger
plastic fuel tank
Yes - but you have to cut off the bracket that holds the oil tank on. Also remove the oil pump and blank off where the oil pump fits on the crankcase and also block off where the oil pipe fits the inlet manifold.capnbluetootharr wrote:Do the E series plastic gas tanks fit on the 200 sr models with the oil tank removed?
Don't forget to add oil to the gas!!
Cheers
I may be old, I may be slow, but hey I'm still getting my leg over - a dirt bike!
capnbluetootharr
Re: plastic fuel tank
Cool . The auto lube was junked many years ago. Just have to find a e series tank nowor a whole bike preferably.
Bladerunner
plastic fuel tank
The rad covers from my E model fit straight on the steel SR tank and the front mounts look the same so apart from the rear mount being different it looks like a straight forward swap!
kdx 125
- Country: GB
- Has thanked: 191 times
Please start a new thread if the topic changes instead of just bringing up an old thread. Thanks.
