6v vs 12v
jtubman
6v vs 12v
Post by jtubman »
I just picked up an 87 kdx200. wanted to confirm its 6v not 12v. was also curious on how that would affect the brightness of a headlight vs a 12v kdx.
i havent torn into the bike yet but it currently runs very well. It has led lights that arent currently working. i know this bike didnt have a voltage regulator. will i need one to get them working?
mwoj
Re: 6v vs 12v
Post by mwoj »
If its anything similar to an 1985 wiring..which it may not be..idk... I can help. Mine is street legal with the tusk enduro lighting kit. If you have an upgraded stator, you will need an AC voltage regulator. From there, you need to purchase a rectifier. This will convert the AC to DC. Then connect rectifier to battery. It will charge the battery. Then you just need to wire in your lights/switches anyway you like directly to the battery.
hbgod
Re: 6v vs 12v
Post by hbgod »
its "6v" at idle on depending on RPM it can make an excess of 12v. Also you need a reg/rec to run anything other than the regular bulbs. a battery would help alot as well.
Hail seizure
6v vs 12v
Post by Hail seizure »
It will be 6V, my '88 is 6V I use a voltage reg from Electrex world. 86-88 wiring is the same.
jtubman
Re: 6v vs 12v
Post by jtubman »
Awesome you guys answered everything.
I plan on street registering this over the winter here in Rhode Island. Ill be getting a tusk dual sport kit and a polisport mmx headlight soon. I have a trail tech voltage regulator and 87 kx250 rear fender on the way.
itll need chain sliders soon and is missing that big chain plate ive seen on stockers. I eould like to get all new guards, and at that time ill be going through the entire swing arm and rear shock.
Dont worry I'll be posting a build thread. Very soon!
Sent from my SM-G900P using Tapatalk
Has thanked: 159 times
Been thanked: 39 times
Re: 6v vs 12v
Look on ebay for reproduction chain sliders, about 40 bucks
Good luck on the build.
hbgod
Re: 6v vs 12v
Post by hbgod »
RI huh? Im in mass, i have a plated 86.
https://www.instagram.com/p/BLGpUkDDbTg ... txrider333
Re: 6v vs 12v
Are you riding it with no chain sliders??!
jtubman
Re: 6v vs 12v
Post by jtubman »
no it has sliders but no plate and a dry rot roller
jtubman
Re: 6v vs 12v
Post by jtubman »
hbgod what front fender is that?
Re: 6v vs 12v
Rollers can be replaced with generic ones from Moose and others, I do believe
hbgod
Re: 6v vs 12v
Post by hbgod »
Supermoto polisport fender. Probably going to replace it with a 15 kx fender.
jtubman
Re: 6v vs 12v
Post by jtubman »
thought you all would appreciate an update. i bought a dual sport kit from tusk but i ordered the wrong one (without a rechargeable battery). i have the battery on the way but as it sits it has a trailtech vapor mocked up and the dual sport kit. i have a key switch and the front brake sensor to put on tomorrow. overall the kit was very easy to add. the rear fender is an 87 kx250 ufo fender. i made NO MODIFICATIONS to the fender. the front hole matched right up but i made holes for the rear mounts. pretty damn easy. ImageImageImageImage
