I have the tusk splitter and installing tools. They make life so much easier for working on these things.
I ordered all new trans and crank bearings/seals for the bottom end. Rockymountainatvmc had everything in stock except for one bushing which I'll try to not fubar when I knock it out before blasting the cases.
Also the seller sent the correct cylinder out today and said they will reimburse me for shipping and my time to send the wrong one back.
02 kx200 hybrid
gots_a_sol
gots_a_sol
02 kx200 hybrid
Much better. A few stubborn spots I'll have to scrape with a razor blade but beats the crap out of how it used to look.
-Joe
Husky WR177 - KX125 (200 soon)
gots_a_sol
02 kx200 hybrid
The correct cylinder arrived today
Fun fact, this piston is stamped .50 on the top but the part number on the inside is for a standard size (pro-x piston). Hmm. Well the caliper doesn't lie. Glad I chose to wait till I had the cylinder in my hands to order a piston kit (the piston matches the bore size)
-Joe
- Tyl3r
Re: 02 kx200 hybrid
Nice, looking good! Thanks for the info on the bottom end tools. I went ahead and ordered the tools as well.
What did you blast the cases with? Do you have to paint them or coat them with anything afterwards?
and P.S...calipers do lie with they fall out of calibration!
gots_a_sol
02 kx200 hybrid
I just threw them in my blast cabinet (craigslist, $100). After I scrub the piss out of them to get rid of all the media, I'll probably spray some clear coat or something on them.
Ok ok, calipers can lie. In fact, this one is usually especially good at lying as it is piece of crap that likes to randomly add 5.08mm to the actual number but my better one seems to have walked off
-Joe
shoe757
Re: 02 kx200 hybrid
I tried clear coat on a 4 stroke bottom end. Peeled like an orange. Just get a mother's mini power ball and throw a little polish on them. It will keep the mud from getting baked on. Actually It might be okay on the kdx since the bottom end doesn't get nearly as hot. Either way let us know!
02 Kdx220
97 Kdx200/220
04 Kx250/500
01 Kx250
01 Kx100
13 Klx140
12 Teryx4
11 kfx450r
05 Vulcan 2000
04 636
93 Cbr900rr 8.37 ET
96 Rm125
97 Kdx200/220
04 Kx250/500
01 Kx250
01 Kx100
13 Klx140
12 Teryx4
11 kfx450r
05 Vulcan 2000
04 636
93 Cbr900rr 8.37 ET
96 Rm125
- Tedh98
- Been thanked: 2 times
Re: 02 kx200 hybrid
You are about 5 months early for April Fools Day.Tyl3r wrote:I am wondering if I can get the cases split with some gentle prying and taping.
Friedom
Re: 02 kx200 hybrid
Haha!
I had a spare rotor cap and modified it with a plate on the inside and a bolt to try to use it to pull the cases apart/push the crank. Got the cases to slightly split, but it was stretching a 3x3 plate right through the magneto cover. No Bueno. I ended up getting the motion pro puller, which was still kind of hard to do right. I recommend the right tools for the job.
"Fun Wheel Drive"
"Fun Wheel Drive"
gots_a_sol
02 kx200 hybrid
I'm sure there are a lot of threads here that folks started but then disappeared never to be heard from again. I try to keep things updated and not be one of those guys
. Well this project hasn't been abandoned, I've just been busy working on another project that I finally got my hands on after 2-3 years of searching. Plus the 125 mill still runs great so haven't been hugely motivated to yank it out.
-Joe
