top end gaskets
bws2
top end gaskets
Post by bws2 »
I'm getting ready to do a top end rebuild on my '01 KDX200.
I've been looking at a gasket set from Cometic.
Do you guys suggest an aftermarket set like this, or should I go with OEM?
Re: top end gaskets
I've used Cometic and Moose (probably just rebranded Cometic) kits with no issues on my KDX, KLX and RMX
Has thanked: 179 times
Been thanked: 46 times
Re: top end gaskets
Cometic is very good.
top end gaskets
No problems with cosmetic at all, perfect fit.
Davenay67
top end gaskets
Post by Davenay67 »
I recently used a Moose Racing top end gasket set. Very complete and everything worked great.
Cometic would probably get the nod as a more quality set perhaps.
bws2
Re: top end gaskets
Post by bws2 »
Thank you everybody for your responses. I see Cometic has two gasket sets for the KDX200, one for 68mm bore and one for a 73mm bore.
Can anyone help me figure out which one to order?
Re: top end gaskets
One is for 200 and one for 220?
pumpguy
Been thanked: 2 times
top end gaskets
Post by pumpguy »
The 200 has a 66+ mm bore while the 220 has a 69+ mm bore.
Can't say for sure but would expect the head gasket IDs would be a bit larger than the cylinder's bore to allow for some clearance.
I would check with Cometic to confirm what is correct for your engine.
