cylinder replating question
bws2
Post by bws2 »
I have a 2001 KDX200 and plan to do a top end rebuild this fall.
If it ends up needing to be replated, I plan on using Millennium Technologies.
Is it better to buy my new piston and rings ahead of time then send them along with the cylinder or should I just get them from Millennium?
Can I assume that the standard 66mm piston is what I'd need?
Thanks
Sullyfam
Post by Sullyfam »
I sent my piston to them, but that's because I already had it. If I didn't, I would have simply ordered them with the replate. Pricing is about the same and it's the easiest path. BTW - they did an awesome job.
pumpguy
Post by pumpguy »
+1 on Millennium. They did a fine job on mine.
I sent them my new piston with my cylinder. I was able to get a deal on a new OEM piston. Otherwise I would have had them furnish the piston too.
They will size the cylinder bore to your, or their furnished piston.
Has thanked: 10 times
Been thanked: 17 times
Re: cylinder replating question
Yeah, doesn't matter. Either send it with or get it from them if you want the best result.
Tyl3r
Post by Tyl3r »
IIRC, it is cheaper if you end up sourcing the piston yourself and sending it along, than buying it from them. I've heard all good things about Millenium. Another option is PowerSeal USA. I sent them mine because they had a shorter lead time at the time and they were a lot closer to me (helped with shipping cost and time).
