The flywheel provided appears to be an H model (based on the numbers stamped on the housing) and the stator mod is simply relocating the mounting slots to sync the coils with the H model magnets. The late model flywheels are not modified for this stator fix. See the following post for the flywheel mod using an unmodified stator assembly.
I'm assuming the pictured coils aren't modified (the ignition coil looks like a Ricky Stator replacement unit) and the distance from center is the same - and since we now know that simply rotating a later model flywheel on its hub also nets a successful fix, we know that the stock coils will work with a later flywheel.
Based on more corroborating information recently found regarding the alternative flywheel modification (see next post), it appears that the stator mounting hole locations are close to a 90 degree change...the picture may not portray that well, but if the flywheel fix is truly a 90 degree rotation the alternative stator relocation should also be 90 degrees. Using a 87 stator in hand, I marked where the fredette modified stator mounting slots are relocated, and it is close to 90 degrees (rather than center of the slot the 90 degrees occurs at the leading edge of the slot when measured clockwise from center of existing slot).
So, there may be a slight difference between the two fixes (assuming the flywheel rotation fix is actually exactly 90 degrees)... which one is best is your guess.
Those who may be inclined to do so can blow this picture up and give it a try....
