hello
i am making a rebuilt of my bike
i want to change crankshaft bearings. i am planning to buy koyo c3.
do anybody have an idea if there is anything else better or more suitable for my bike?
do i have to put c4 ?
thanks
makis
kdx200 e crankshaft bearings
Dekon
I would only go with the factory Kawasaki bearings(I also used OEM crank seals). I feel that if my bike got 27 years out of the original bearings they must be good. I know they were the original ones because the PO never split the cases in the years he owned it and it was a POS when I got it. All bearings that I replaced inside the cases were replaced with OEM bearings. Who wants to split the cases again to save a few bucks?
- Has thanked: 181 times
- Been thanked: 46 times
Re: kdx200 e crankshaft bearings
I would assume that the factory bearings were made by Koyo, a Japanese bearing company. They made a lot of the E series engine bearings. If one can get the EXACT same bearing from a bearing store, it could be cheaper. One of the tricks is knowing which specification each bearing is. Some are the EXACT same size, but not recommended for certain RPM's, I believe.
Some bearings may have been custom made for Kawasaki, but a lot of the bearings based on dimensions can be found. BUT, same size does not always equal same bearing spec.
- Tedh98
- Been thanked: 2 times
Crank bearings and seals arent the place to try and save a few bucks. Just go with OEM.
