Air box/ snorkel tips?
Moebraap
Post by Moebraap »
Anyone have any tips on How to take out the air box. ?Trying to put this carb in single handedly can be a real b**** haha :rock:
canamfan
Post by canamfan »
Remove the subframe piece that bolts on and it will come out the side. H series If your just installing the carb hold it up in position, install the slide and tighten the cap push the back of the carb into the airbox boot enough that the front clears the intake boot, then push the carb over and slide it into the intake. If the airbox boot is not as flexible as it once was, you can tighten the clamp on the back of the carb before you pull it into the intake side. That way the carb won't pull out of the airbox boot.
Moebraap
Re: Air box/ snorkel tips?
Post by Moebraap »
What series is my bike? its a 1990 KDX 200
http://s50.photobucket.com/user/moebraa ... v.jpg.html
Has thanked: 160 times
Been thanked: 40 times
E
Moebraap
Post by Moebraap »
Im having a problem finding them subframe bolts for the airbox. Can youhelp
It is a sub pipe, not really a sub frame. It is the left rear frame bar that bolts in / out.
Moebraap
Post by Moebraap »
Do you mind sending me pictures?im lost buddy. I appreciate you helping me out! :please:
the bar that the coolant tank mounts on, about 1.5 feet long
This is where having a service manual pays for itself.
Dekon
Post by Dekon »
Look at the third and fourth pictures, the sub bar is removed in picture three and installed with the air box in picture 4.
http://www.kdxrider.net/forums/viewtopi ... 03&t=14595
Also looking at the picture you linked, it is a good idea to route the front brake line to the inside of the fork, catch it on a branch or something else in the woods and you'll more then likely tear it off.
Moebraap
Post by Moebraap »
Thanks
