stem is in
layoutd
stem is in
Post by layoutd »
got the stem in the kx tree, $25. they were skeptical that they could do it, but it turned out great. now i have to wait until tuesday for the bearings to come in. so no riding this weekend.
Eatin' ain't Cheatin'
Green Hornet
Post by Green Hornet »
was was "skeptical "
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
they they was! :?
Good job! You gonna love it....
Hey, all right, layoutd! It sounds like you are almost there.
What year model is your KDX?
What are you going to do with the leftover parts (KDX clamps and KX stem)?
Thanks,
Jason
layoutd
Post by layoutd »
i have the exact same set up as described on the sticky. i have a 98 kdx and am replacing with 96 kx 250 forks.
they were skeptical in the ability of the parts to hold up during the job. one guy at the shop acted like he had sone some stems and the stem had gotten messed up some how, not sure, he was not specific. i relayed all information that i had read and got the typical"well, you can't believe everything you read" thankfully he was not the one that did the work. the guy who did it never had before and just gave the old "well, we'll give 'er a try" and he did a fine job.
i guess i am goin to hock the parts on ebay. know anyone that wants them without bidding?
KDX220PHIL
Post by KDX220PHIL »
Cool! Tell us how you like them.
Remember to fill out the Required Knurling Sticky, including year, model, and country of origin of KDX and KX Forks.
Thanks,
Phil.
Green Hornet
Phil-Are you going to press ypur own stems??
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
KDX220PHIL
More than that, I will machine my own if there is any modifications required.
Green Hornet
If you come up with a machined stem, let me know
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
KDX220PHIL
Will be no problem Greent Hornet, Wish I had the stem specs for each year to year conversion. I am guessing that the knurling did not have to bet too accurate, providing it was slightly larger than the size of the bore. The remaining material, above the size of the bore, would be displaced back to where it came from?
Green Hornet
The KDX Specs should be the same, Right. What about the KX Stems.
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
layoutd, thanks for the info. I might be interested in the KX stem. Send me an e-mail whenever you get time.
Green Hornet, that is what I have. I prefer no knurling and no washers.
Thanks,
Jason
Green Hornet
Hook me up, how muchhhhhh
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
Well, I haven't really thought about that. E-mail me and we can discuss it, though.
Thanks,
Jason
KDX220PHIL
Green Hornet- there is a sticky "Required Knurling" That shows KX and KDX stems that match according to part numbers. I was refering to the KX stem geometry and how the KDX stem must be altered to fit the KX triple tree.
If your TT's are 99-01, wich they are 99's to an 05 KDX220 I thought I read somewhere that they do not require modification, I could be wrong though. I just tried searching for it and couldnt find it.
KDX220Phil, don't read too much into the numbers. They don't always tell the whole story. :wink:
KDX220PHIL
Meaning?
Numbers that dont match may fit, but may not. Numbers that do match will fit??? :?
I just mean that the numbers don't tell the whole story. That's all.
canyncarvr
Post by canyncarvr »
Phil:'If your TT's are 99-01, wich they are 99's to an 05 KDX220 I thought I read somewhere that they do not require modification..'
If I get this correctly, my fork-set was advertised as being from a '99 KX250. The KDX stem I got for them DID require modification for an acceptable press fit. According to the spec of the LocTite product I used, it could have taken up the gap..but I DID have the stem knurled. The machinist doing the work said he did not have the ability to knurl an inside diameter..the clamp. That seemed odd to me, but that is what he said.
KDX220PHIL
OK, great CC, glad to hear that info, do you mind adding it to the sticky?
To knurl an inside diameter it is more difficult. The diameter being knurled must be mounted to a machine (usually a lathe) so that the center axis of the hole is concentric to the lathe axis.
This requires "dialing" the diameter to be knurled concentric to the machine axis so that you get an even pattern around the diameter.
The internal knurling tool is then inserted in the hole and force is aplied to the wall of the hole with the tool.
He either didn't have the tool, knowledge, experience, or/and he would have had to charge more for his time.
This is not the best example of a internal knurling tool, as it is too big for this purpose ( diamond pattern):
http://www.accu-trak.com/pictures/8diehead.jpg
here is another, this would work (straight pattern):
http://www.accu-trak.com/holders_internal.html
