Who makes a hub cap delete for the mileage gauge?
				Willbilly
I saw it posted once and am not having any luck finding it again.
I'm looking for the aluminum hub cap delete that eliminates the mileage gauge.
Thanks
Thanks
 - Has thanked: 48 times
 - Been thanked: 15 times
Re: Who makes a hub cap delete for the mileage gauge?
Zip Ty Racing used to make one. You may want to call them.
- Tyl3r
I guess I'll share this haha it says its the last one.  I was thinking about buying it, but probably won't.
http://www.ebay.com/itm/262187522167?_t ... .S1.R1.TR1
Only one I could find anywhere!
				Willbilly
Thanks guys.  I'm not looking for a cap to the existing spacer.  I'm looking for a spacer replacement.
				sarrant
Why? The existing gear housing is already cast and matched to fit that space and protect the seal perfectly.  There's no real weight to be saved or anything else with a custom spacer.
Ah, OK.
				gravelcruiser
Maybe a little too redneck, but I used black silicone to plug the hole and it works great, is not noticeable, and is removable if you decide to put the odometer back on.
				Pipeliner
I did the same exact thing with the silicone. I stuffed a rag in first then sealed it up. Works great!
