1993 E series USD clicker settings
bultaco4ever
Post by bultaco4ever »
So, I have a 93 KDX200 with freshly rebuilt, stock, upside down forks. I should have put some stiffer springs in for my weight but I didn't. (I'll do that this winter). But for now, if I want them to be as firm as they can be...should I turn the clickers on the bottom of the forks all the way in (clockwise) or out (counterclockwise)?
KDXohio
Re: 1993 E series USD clicker settings
Post by KDXohio »
IN would be stiffer
Has thanked: 126 times
Been thanked: 33 times
NOTE: Always gently turn the adjuster. They are a little fragile if cranked on.
I will second KDXohio, clockwise (in) is more damping. Counterclockwise is less damping.
You will need the springs from Race Tech or FRP to fit in the forks. 1995 - 2006 KDX springs are JUST barely too wide to fit in the tubes.
bultaco4ever
Thanks for the tips
