Broken clutch cable eyelet on engine case
Jpm1109
This more me venting than anything. Has anyone else's clutch cable eyelet broken on the case. Can I weld a new hoop on there? Lol. Frustrated.
gabegarcia
Re: Broken clutch cable eyelet on engine case
Give a picture?
Sent from my SAMSUNG-SM-G930A using Tapatalk
- Has thanked: 50 times
- Been thanked: 17 times
Son of a whore. I already have the mental picture. Sorry to read you have that issue. I don't know how to fix it, but the first step is usually to curse at it. I have done that for you. Now, if someone else knows how this can be repaired, please do tell. I know I have seen it before.
Jpm1109
Haha. Curse at it I have. I'll try to post pics tomorrow. In bed about to dream of sweeping trails and small obstacles.
cornishwrecker220
You should be able to get it welded ( provided you still have the broken piece )
Or you could fabricate a piece of steel that attatches to the clutch case bolts with a loop for the cable to fall into ....similar to the Suzuki drz set up
- diymirage
what corny said
I would try to make one myself
picture the chain guard and your halfway there
(cast aluminum can be welded, but its not as easy or cheap as welding steel)
-1997 KDX 220 project bike
Jpm1109
A little less than half the hoop is still there. Broken piece gone. I have the cable resting in what's left with the cable nut tightened as much as I could without forcing itself back off. Then I skillfully applied a zip tie in sailor knot fashion. Lmao
Ride it that way while you wait for an inner clutch cover to show up on ebay. You could use some JB weld to form the broken part just to hold it all together inthe mean time.
Jpm1109
Good call. Didn't occur to me that there is a separate inner clutch cover. I'll keep an eye out and swap it with the next clutch service.
- two-stroke-brit
This the second one i have seen broken at that spot.
She might not be pretty but always a fun ride !
ubareddition
Stumbled on this video and wondered if it would help you out.
Sent from my SM-N910V using Tapatalk
Jpm1109
That would maybe work if I still had the broken piece. But good info either way
